Wiring Harness
Choppermike
Wiring Harness
Post by Choppermike »
Now that I solved my lowering issue, I want to see if anyone has used EZ-Wiring or Painless wiring harness. Is one better than the other, the same? Any issues with one or the other?
Mike
1962 F100 Unibody- Ol' Jack
65 Mustang Coupe
92 Mustang LX
2006 Mustang
[albumimg]3443[/albumimg]
f100matt
Post by f100matt »
I bought a EZ wiring harness, but never used it. I heard that Ron Francis wiring makes factory style harnesses also.
www.ronfrances.com
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
Rosati
Post by Rosati »
I used the painless 18 ckt universal truck harness in my 64. But not much is stock in mine. Switches, ignition, charging system, etc are all updated or replaced so I cannot attest to the compatability with a stock system.
However, from reading the entire instruction booklet sent with the kit, you should be able to make it work.
If you plan future upgrades, like power windows, locks, A/C, etc. get the 18 ckt. Run the wires to the proper place andjust fold the wires back into the loom. Thay way, when your ready to hokk them up, you just need to grab the wire and go.
You will need to retain all connectors to terminate the harness, and I recommend soldering and shrinkwrapping everything.
Crimping is OK for temporary repairs, but you wouldn't want your ride burning to ground because a crimp fell off or broke a wire.
I hate Message Boards.
castruck_1964
Post by castruck_1964 »
:iagree: butbut.gif my application was not stock either :roll:
but i have used painless on several vehicles I have done for others with no issues.
Slicks rule
dd/ 19 F150,97 Tbird
62 swb bbw uni next project
460 C6
Ken
GDG
Post by GDG »
I used an EZ on a street rod build and found it to be very EZ, I'm going to use EZ on my 64.
Doug
PFM-64f100
Post by PFM-64f100 »
I used a Ron Francis harness on mine. I went with the "FORD POWERED ORIG BARE BONZ WIRING COMPLETE WIRING SYSTEM". The system was easy it came with a new Head light switch. You basically have a bunch of wires (all labeled printed on wires) that you cut to length after running them. This worked because I didn't always use the original path. It was a fairly easy system to use and it replaced everything including the wires going to the tail lights. I am happy with it some don't like it but it works great for me.
Picture of unit installed (I did leave a little extra wire looped up) and yes you can install it just about anywhere.
