Propane Company can kiss my behind
Got our outdoor wood furnace all hooked up today and it is working GREAT. It is heating our water and my garage also. Propane has doubled in price since we bought this House 4 years ago and now the only gas I will be buying is gas for the Chain saw and wood splitter but it wont be near what we were paying for heat. I havent heard our furnace kick on it n over 2 hours now but the gfan is blowing heat, YEEHAWW
Good for You!!!!!!!
I need one of those.
you guys are probably tired of hearing from me on this, Furnace hasnt kicked on in over 14 hours and our house is 70 degrees. I went out at 6;30 this Morning and stoked the fire and it should be good till tonite. Got heat going into my Garage also. Well I need to go get the chain saw fired up and get busy. Planning on cutting wood most of the Day today.................Kid
warm and happy
warm and happy
Slick Fan, check out this link, I got the smaller one and it seems to be doing great.
http://www.centralboiler.com/
- Truckfarmer
Kid, a couple years ago, I looked at adding a corn burner to my heating system. That was when corn was $2/bushel. Now it is $4/bushel so the payoff has been moved way back. Still considering it because I don't want to buy a chainsaw and splitter. Besides, I am surrounded by corn.
I am sitting here right now enjoying the heat from the fireplace insert we have. The heat pump isn't doing squat, lol. Biggest problem I have is having the time to get wood split. This year I'm doing things different though, gonna split it as it's stacked.
- banjopicker66
biggest problem i have is overworking myself. rarely can i cut 2 days in a row. probably cut/split 4 cords since end of October. no power splitter. need to put my saw back together, had a bar oiling malfunction .little pin rollers from the clutch bearing came off and wedged in the pump and the little plastic drive gear got chewed up. borrowed a friends saw, worked ok but a lot smaller than mine and not a skip tooth chain.Greg D wrote:I am sitting here right now enjoying the heat from the fireplace insert we have. The heat pump isn't doing squat, lol. Biggest problem I have is having the time to get wood split. This year I'm doing things different though, gonna split it as it's stacked.
Greg, I considered a corn burner but decided against it when the corn prices started going up. The stove we bought has a corn burner option if I decide I want to add it later on.
sometimes when we go cut we take a splitter with us and split it as we cut and load it up. It makes it nicer when we go to unload it that it is ready to be stacked and burn.
I am going to go look at new chain saws today and am thinking about selling the 79 2wd F250 I have so I can buy a 4x4 to use.........Kid
have you calculated how much time you spend cutting, splitting and keeping the fire going?,, wear and tear on your equipment, your body.. how much are you saving yourself?
________
GM Family II engine history
________
i speed one day every twoo weeks cutting wood. if i paid myslef buy yht hour it would cost about 120.00 every two weeks. just labor alone. i can run almost all winter long on 2 gallons of gas mix. and one gallon of bar oil. my saw maintence is about 25.oo per year for sharpening chains. gas to go get the wood is about 10.00 each trip. so yes it does seem to cost me more if you figure in paying myself. but atleat i'm paying myslef and not someone else. at least if i dont get paid i would get shut off. other rude comments about oil and george bush withheld. besides i like cutting its alot of fun to get out and do it. i only cut dead trees so i am also helping to keep the farm cleaned up.
in well over 20 years i have saved a lot of $.
i have an old saw, do all my own repairs and maintenance including filing the chains. repairs and maintenance of the saw cost me very little.doubt i have ever used 5 gallons of gas in a year of cutting.even bar oil is not an issue, i hauled a lot of junk cars that had bottles of oil and tranny fluid in them and use those.used motor oil too.
wear and tear on me is not a problem. couple hours a week of work/exercise is good for a person. getting a bit older i pace myself a little more on it but its not killing me.
fordmans observations are true.
any wood i buy the $ goes to a guy trying to make a living, not a gouging corporation.
anything i cut down is dead and going to rot or maybe help fuel a forest fire.
bought a log truck of wood this year $800 for 10 Alaskan cords, enough for all winter.
[albumimg]3005[/albumimg]
couple minutes twice a day to feed the dragon is not worth worrying about.
costs $85 to buy 1 month worth of lp to run the cookstove , clothes dryer and water heater.fuel oil is just as bad.
recently bought a wood cook stove, started air drying clothes and working on heating water with wood too.
spend a lot of $ or do a bit of work, ill do the work.
