Looks like they have the same issues as the old mustangs, I have alot of the same things going on with the 66' coupe, that cowl is a PITA. Good luck.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
That's kinda odd that the cowl is rusted that bad when the rest of the car is as clean as it is. Nice to see that you are repairing the right way rather than some of the crap some people do.
You've been a busy guy! Looks like you're definitely fixin' it up right.
My wife's first car was this '68 289 'Stang. She got it in 1983 & even by then, the cowl was rotted on the driver's side & in turn, had rotted the floor. We found out exactly how bad it was AFTER the sale was done.
There was a piece of plywood covering the hole in the floor, with carpet over the top. Live & learn.
My first Slick (Caribbean Turq 65 lwb 240 3 speed) was rusted so bad the it would lock up the column shifter if I went around a corner too fast (I finally supported the cab with a 2x4). I am now on my 7th slick, we learn, we cut and we weld; life is good!
The frame, rear cogs, shifters and headset are the only original parts.
With shoes I have about $3500 in it. I used to ride all the time but I have to drive an hour to get to any decent hills.
