different truck slowing going uphill
willy3486
Post by willy3486 »
I have about had it with my everyday truck. I have a 91 b2200 truck I bought in November. I was told by the mechanic I paid to get it suposively fixed that it was a 2.0 engine. I got a webber carb put on it. He tried a bunch of jets trying it out and replaced the vaccum advance and some hoses. It took him 2 months to put the carb and the vacuum advance on. All the while he drove out a tank of gas. He "had" it working but it started doing the same thing it had done since day one. It will run good at first then all of a sudden it will start sputtering and slow down to about 20-30 mph. It will barely move and I have to pull it over. I can start off on the road again but it will get to about 30 and start sputtering. It will bog down and I can give it all the gas and it just sputters. It will sometimes start going faster and the RPM sometimes will jump up to 4000 but it will sputter and go down in rpm again. I have noticed that it does this mainly when I start going up a steep long hill or when I start to get on the interstate and have to get up to speed. If I stay on flat land it seems to never give me trouble but when I try to go up a hill is when it acts up. In fact its one of the best running vehicles I have ever driven when its not acting up. Then when I get on smooth land again it will drive fine, with just a few sputters. I have had it with this piece of S#%T. The mechanic I had to look at it can't figure it out and I don't want to sink any more into his repair bills. Has anyone seen this and give me an idea of what to look at. I have a automatic transmission and one guy told me these transmissions have coils in them to switch gears, But the thing shifts really smooth.
Todays drive in,
I drove in today and it run fine. But who knows about the next time. I got the best gas I could and filled it up. I also added some carb cleaner in it. It makes you want to take a gun and put it or yourself out of misery. I have got to where I hate it. I am thinking about cutting my losses and selling it. Let someone else have a go at it. But what gets me is that it doesn't do it every time and when it acts up it will sputter and stuff till you park it for a few hours. Some of you will love this, I checked the takeoff and this morning 0-55 took 60 seconds.
Johnny Canuck
Post by Johnny Canuck »
These sound like the symptoms of a Duraspark box going south, so I am gonna go out on a limb and say its your ignition computer, heading for the weeds..(if it has one) :?
Slick Fan
Post by Slick Fan »
Definitely sounds like it's time to go truck shopping.
We has a few on those Mazda's for delivery trucks when I worked in the parts store...those things have probably 700 feet of vacuum tubing in them. Makes it tough to find a vacuum leak. I wouldn't give $1.56 for a dozen of 'em. :roll:
jwh f-100
Post by jwh f-100 »
Johnny Canuck wrote:These sound like the symptoms of a Duraspark box going south, so I am gonna go out on a limb and say its your ignition computer, heading for the weeds..(if it has one) :?
Willy, Johnny's thought is a good one, they can cause some strange problems.
Kinda sound like a lack of fuel also. You mentioned it ran good with a full tank of fuel, maybe a tank pickup issue. Could be good with a 1/2 tank on the level then on a hill the fuel level may be lower on the tube.
I had a "dentside" Bronco that acted just like you discribe. It ran great for a couple miles then would crap out. If I was easy on it it would go further or would idle for ever. Although it never leaked the issue I found with that was the short rubber hose going from the tank to the steel line was rotten and sucking air.
Jason
Beer will change the world.
I don't know how but it will.
since it only happens going uphill, fuel lines,fuel pump, filters and float setting should be looked at.
weak pump may not want to pull that fuel uphill. rusted line with even a tiny pinhole will aggravate this more.
willy3486
Post by willy3486 »
As far as tubing it does have a lot of them,but most of that tubing is done away with the webber carb. So I have very little amount of tubing. It looks like the mechanic replaced the tubing that matters. As far as the tubing on the gas lines I may replace that first. If I can figure out where the gas filter is I will replace that also. I think the gas pump is electric on this truck. I think the mechanic tested it and it got good pressure. Its almost like it floods it out. I have been pricing newer autos at the new car dealers used lot. If I go that route I just about have to find another job to pay for it . But that may happen anyway if I get a better paying offer and any offer would probably beat what I am making now. As far as Duraspark I will check that when I figure out if it has one and what a duraspark is. I hate to get rid of it if I can get it running right. I am afraid to even check with anyone local. The guy who sold it said it ran perfect with no problems and the mechanic had the truck about two months and it still does the same thing as what I wanted him to fix. Plus the engine seems to be running great otherwise. The rest of the body seems perfect also. Everything seems to be tight and good. The body is perfect except for a faded paint job.
ras4434
Post by ras4434 »
Just like there is a great bunch of guys on slick 60 that seem to be able to come up with the correct answer to most slick questions, I wonder if there is a site for Mazda folks. If there is I bet they would be able to diagnosis the problem in about 30 seconds............from past experience dont ya know............just a thought. My dad had a B2200 that had similar problems. Seemed the mechanic used the wrong type of tubing for vacume. WHen it got hot enough it collapsed and virtually stopped the truck.
willy3486
Post by willy3486 »
JWH f-100 and the ice man hit it on the nose I think. I stopped by today at the parts store. had thought about replacing the gas lines a few days ago and they confirmed what I thought. Anyway I asked about the hose size and the parts guy said he could look at it. After we raised the hood I was showing hin the line to see what size he thought it was. When I grabbed the line it was loose and you could then see it had a split down the side at the clamp. So I got about 6 feet of hose and clamps. For the time being I just cut the split out and put the orginal hose back on with a clamp. I thought I would do that in the parking lot. It drove better than it ever has. I went down a 2-3 mile long hill turned around at the bottom and started up. It had good pickup and I was able to get it to 55. In fact it had a faster 0-50 up that hill than it had when I was on level ground. This weekend I plan to replace all the gas line hoses with the new I have. I do belong to the mazda truck forum. I posted there but I got a lot more responses here. I guess this is home. Thanks again.
blackagatha
Post by blackagatha »
this is home because our trucks are cool. I cant really picture the Mazda trucks finding a huge following of devotees like the slicks have...
Glad you found the problem.
It's funny kinda, I've taken to doing a lot of work in the parking lot at the parts store (minor stuff anyway) like all my messin with the carburetor... I'm far enough away from the parts stores, and being at school, I don't have any real good place to work anyway, so I just do it there. Save myself quite a few trips, you know how stuff like that is, not realize you need something until you get working... like the chunk of fuel hose to the carb I replaced... stupid crap that would have meant another trip...
DocDave
Post by DocDave »
Fuel pressure check while it's sputtering. Hook a guage right into the line and drive it till it starts sputtering.
If thats not it I'd check the crank sensor. Sometimes warmed up sensors open small cracks in the sensor face and dont get the signal.
Failing that it may well be computor controlled ignition or module.
If you get an improvement with the fuel filter, you may also need a fuel pump.
Nasty thing trying to diagnose an intermittent problem,
Dave
Just reaized it's not injected. Probably doesnt have a crank sensor. :roll:
Fuel supply problem or ignition box, possibly coil or ignition module.
mikecarson
Post by mikecarson »
I just had a similar problem. There was a cracked hose between the fuel pump and the outlet INSIDE the fuel tank.
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
