Took a few truck pix today
Phil
Post by Phil »
Gonna figure this camera out eventually
"Whitey Ford"
Post by "Whitey Ford" »
Heavy-
Looks awesome. The background is pretty cool as well. Have a question though. Is there anyway you can take some pics of your hood spring assembly under the hood. Yours is so straight and matches the lines great. Mine are way off, almost like the hood is an 1" above the matching body lines. How did you get it so straight? Or did my PO screw mine up(thinking out loud)?
I have new hinges he gave me with the truck but I noticed that the bottom of the hinge of the drivers side is hitting the wheel well by the firwall so it wont set any further down. Should I cut a notch and the re drill the bolt slots in the hinges so I have more play to move the setting up and down?
Anyway good looking truck.
Girls love a pick-up man.
jwh f-100
Post by jwh f-100 »
Yeah OK Heavy, You don't know how to use a camera and your car is junk... Tell us another one..... :wink:
How about some burnout pics. :D
Jason
Beer will change the world.
I don't know how but it will.
Slick Fan
Post by Slick Fan »
Great pics, HH! :cheers: Let us know when you finally get that camera figured out. :wink:
[quote=""Whitey Ford""]Heavy-
I have new hinges he gave me with the truck but...[/quote]
Are they really NEW hinges, or just clean originals? It sounds like maybe those hinges have worn bushings too & that's why the hood doesn't suck down tight in the rear. :)
Paul Merrell
Post by Paul Merrell »
Whitey Ford you need to look at the cab mounts they are problably rusted out. It lets the cab down in the front and makes the body lines not line up.
Phil
Post by Phil »
Really I am trying to learn the camera. Its like a lower mid grade 7mp Kodak.
I wish I'd have saved more green for a DSLR :(
I hang out on a few car forums and the guys on the ricer forum are amazing pichertakers.
As far as the hood that's the way it came. It does stick up in back about 1/2" so I just force it down. Recently I added a piece of hood to cowl weatherstripping I had on my wrecked car. It tightended up the hood and it stopped a hellish rattle
Here are some of the ricer guy's pics
This guy just moved to AZ from Toledo
Hate the cars all you want but the pics are stellar
Slick Fan
Post by Slick Fan »
Good point Paul, I was assuming the rear of the hood was popped up above the cowl line.
From what I know, this is usually indicative of mushy front cab mounts. So stop me if I'm wrong, you guys. :mrgreen:
The front of the cab settles, pulling the hood & lower fender edges apart, as in this pic I shamelessly swiped from Greg D... :lol:
This is a mild example, they can get worse as the cab mounts fail even more.
"Whitey Ford"
I believe yall are exactly right. Thats the only thing on my truck that is truly rusted and its the front cab mounts..well the drivers side and trying to think but thats the worst side. Ill be damn. ANyway the onbes on there are pretty clean and good but the PO gave me some new ones. Maybe he though it was the same problem as well but I bet its the cab mounts becuase the door seams are a little off as well. The top of the door is closer to the front fender than the bottom of the door so Im sure that means its sagging. Sucks that its the problem but great that I learned somehting new today. Well after I fix the mounts (i think I posted a forum about that) then I may have an extra set of brand new hood hinges to sell hahahaha.
OK well I may repost that cab mount question since I think the last one didnt have many responses.
Thanks to everyone...Im just happy I learned some new stuff about my truck.
Paul Merrell
Slickfan my truck looked worse than that as far as the body lines my fenders would not line up and hood. Looked at the cab mounts nothing there the cab was sitting on the frame. After replacing the hole cab the cab sits about 1inch off the frame if my memory serves me right.
blackagatha
Post by blackagatha »
well, I MAY be mistaken, BUT....
I am 90% positive that the gap between fender and door is straight on aggie. Hood sits up about an inch, and is really hard to close.
That pic.... Big OL crooked gap.... but look how nice the hood sits down! that pic proves nothing to me. I can only wish my hood would sit down like that!!!!
I have found that if the springs are removed from the hinges, it relieves the bind, and guess what, the hood sits down nicely. SO I guess I could remove the springs and use some of those trunk struts or something... I think that may be our best option short of all buying brand new springs. Maybe put a really weak spring on the hinge to keep it from rattling, if deemed necessary, and use a big strong strut cylinder mounted on each side, just in front of the hinge...
Johnny Canuck
Post by Johnny Canuck »
BA, simply put, your hinges are plumb wore out.New springs will only make it WORSE.
New hinges will help, until they too wear out.
The best solutions in here are in Alan McLennan's album and ElPolako's.
blackagatha
err yeah, I got mixed up in wording... I intended to say new hinges. I realize that the springs are not the problem.
I think if you thought about what I was trying to say it would have been clear what I meant to say....
I like El Polacko's setup for cool factor, ease of operation, and durability factors, BUT.... I like to be able to lean in the front of the truck. I have never taken to leaning over the side to work.... these trucks are slightly snubnosed and wide in the front, unlike many cars that come factory like that IE some Corvettes, Jaguars etc with a LONG narrow snout... Makes more sense to dive in the side on those.
BA, If your still young and nimble enough you can hop in the engine bay and work :lol: ,I`m to stiff for that these days but I can pull two clevis pins and the bonnet comes off and goes back just as easy with no aligning required, not my design I just copied it to prove to myself I could do it, and mine works just as well as Elpako`s I think. Maybe I do a video one day, maybe one day I`ll go to the moon to :lol:
Alan,
blackagatha
im betting on the roadtrip to the moon!
ezernut9mm
Sweden
Post by ezernut9mm »
truck looks killer hh. and those slammed scubies look pretty mean as well. the only import i'd own and drive.
