Bought a humongous compressor the other day, need tank
Nice compressor, but without tank. Guy I got it from bought it for the tank, now I have the same problem. 15 horse motor and big twin dual stage 4 cylinder compressor. Need a tank I can run at 175 pounds. I've found several used tanks on Ebay, but worried about the age of some of these tanks. 25 years old on the one I like. Running that much pressure, I'm worried about a blowout, from inside rust. Any thoughts on the subject?
Have a great day,
Have a great day,
I totally agree. Don't put a used tank on that large of pump. Most of the time, you never know the age or history of a used tank (has it been in a fire?). Get a new tank with proper specs. It's a lifetime investment. Here are some at Grainger. You can probably beat these prices.
http://www.grainger.com/Grainger/wwg/pr ... 1=Tanks%2C
Good luck
Good luck
Jim
dont know if it will work or not, but my grandpa used an old propane tank for his compressor, he got it used from a house they were bulldozing, he didnt use that high of a pressure, but it had lots of capacity, plus it wasnt rusted inside because of the gas it previously held, just something to think about
________
easy vape vaporizer
________
easy vape vaporizer
worked at a shop that used a propane tank,
worked fine. be sure to put drain valve on bottom.
why so much pressure? most air tools only need about 125 max.
blackagatha
I figure the more pressure you can make the better, the longer the reserve will hold out... Say your propane stove only needs 5 psi to work... Why pump the tank up to 50???
And just IMAGINE how hard you could punt a potato with 175 psi.... HOLY CRAP! You could lob bowling balls with that much pressure...
can I be your new buddy????? hahaha
thats true , but with that big of tank, it will have plenty of reserve
also its a lot tougher on the compressor to pump against that much
pressure
in other words= wear out faster....and less $ efficiant
pressure
blackagatha
nothing saying you cant turn down the regulator to keep the preesure down on regular basis, but to be able to crank it all the way up do do some serious carnage in the backyard.... and imagine what you could do with the blower nozzle... serious cleaning power!
Yes it is a 3 phase motor, but thought I might put a little diesel engine on it. Have it in mind to sandblast with it. Won't be in use all the time. I have four other compressors. One is a gas unit I just bought that runs off a 13 horse kohler engine. Produces 27 cfm at 100 lbs. , according to the specs. Runs at 175 pressure in the tank. Bought that after I bought the big compressor. The big one came with acouple air coolers for water , and I got a bargain on everything. Couldn't pass it up. Even buying a good used tank I will have less than 1000 in it. Thought about the propane tank thing or if I can find a couple of large cutting torch air tanks. As far as the 3 phase, most likely will use a three phase converter and run it on 220. Set it up to run to the storage tank outside and maybe mount the unit in the attic. Just doing some tire kicking. No sure I will need the big unit after buying the smaller unit. Thought about building a place to do blasting in so I can conserve on the sand blast media. Really makes a mess outside my shop, and I track it in. Small unit I've been blasting with builds to much heat in the compressor, and then water gets into the air line causing the sand to get wet and clogging up the unit.
blackagatha
ya know you can get an air dryer for real cheap at Harbor Freight or similar chinese tool supply. they work really nice.
a bank of air bottles would work well. you would have to have a lot of them to make any real capacity though. probably get expensive quick.
The diesel might be doable. I have a little Kubota tractor with a 3 cylinder, 17 HP engine. I think they may even have a 2 cylinder. I know they are real gutsy engines. Can't hardly kill one of them. Might be worth looking into.64 f100 wrote:Yes it is a 3 phase motor, but thought I might put a little diesel engine on it. Have it in mind to sandblast with it. Won't be in use all the time. I have four other compressors. One is a gas unit I just bought that runs off a 13 horse kohler engine. Produces 27 cfm at 100 lbs. , according to the specs. Runs at 175 pressure in the tank. Bought that after I bought the big compressor. The big one came with acouple air coolers for water , and I got a bargain on everything. Couldn't pass it up. Even buying a good used tank I will have less than 1000 in it. Thought about the propane tank thing or if I can find a couple of large cutting torch air tanks. As far as the 3 phase, most likely will use a three phase converter and run it on 220. Set it up to run to the storage tank outside and maybe mount the unit in the attic. Just doing some tire kicking. No sure I will need the big unit after buying the smaller unit. Thought about building a place to do blasting in so I can conserve on the sand blast media. Really makes a mess outside my shop, and I track it in. Small unit I've been blasting with builds to much heat in the compressor, and then water gets into the air line causing the sand to get wet and clogging up the unit.
Jim
