bedside seams
62galxe
bedside seams
Post by 62galxe »
just curious what is used before the seam sealer is applied.thought about por 15.what works for yall.
62galxe
Post by 62galxe »
no special prep tips for the seams?
GDG
Post by GDG »
Seam sealer should go over the primer.
Doug
Slick Fan
Post by Slick Fan »
GDG wrote:Seam sealer should go over the primer.
Doug
Although I have yet to do this myself, I agree. That's what I've noticed most other folks have done.
My personal opinion is "weld em up & fill em". 8)
jwh f-100
Re: bedside seams
Post by jwh f-100 »
62galxe wrote:just curious what is used before the seam sealer is applied.thought about por 15.what works for yall.
Yes something like that should be used, then primer, then seam sealer, and possibly prime again.
I think when I do my bed I am going to try using a brush along with regulated compressed air to try to get the rust converter/prohibiter to penetrate deep into the seem. To the point it "bleeds" out the other side.
Jason
Beer will change the world.
I don't know how but it will.
62galxe
Post by 62galxe »
thanks. now to get busy on the truck. :roll:
helicorbin
Post by helicorbin »
Pro-Seal (aircraft sealant) you can shape it nice with soapy water and its paintable ! I use the stuff on rotors that spin just under mach at the tip under 122 g's at 110% power, and I have used it to seal fuel cells. In other works you wont have to mess with it for a while. ha-ha
I think you can get a tube or qt of it around George Bush Interc. Arpt.
helicorbin
Canyon Texas
