I need some parts
Uncle Skip
I need some parts
Post by Uncle Skip »
Finally, a use for one of those old worn out wiring harnesses.
I need the two inside and outside wiring plugs that go thru the firewall, and an extra ignition switch if someone has one laying around.
Really, that's all I need.
I'm either going to be a Slick Wiring Genius, or a complete and total idiot.
Believe it or not, I actually went thru and identified each wire and what it goes to, even the turn signal cam.
My custom wiring harness went south and I can't seem to fix the problem (I know what the problem is, I just can't fix it) so I'm going to build my own, I think using the original switches.
Think one of you can bail me out?
Anyway, if I'm a success, I'll share what I know...........
if not, well....................................................
Bwahahahahaaaaaaaaaaaaa
Tio Skip :twisted:
Jarrod
Post by Jarrod »
What happened to your custom harness. Wasn't it built by a guy here? Is he helping you trace the issues?
Cheers,
Jarrod
jwh f-100
Re: I need some parts
Post by jwh f-100 »
Uncle Skip wrote: I'm going to build my own, I think using the original switches.
Doing the same here.
I'm making a diagram in my head and have supplies on the way. (Butt connectors not included :) )
Good luck and enjoy.
Sorry can't help with the connectors. They will not be used with my new harness but I'd like to save them.
Jason
Beer will change the world.
I don't know how but it will.
racerx1699
Post by racerx1699 »
I have the connectors, but no switch. You can have them, I'm going with a Painless wirering harness in mine when I get that far. PM me with an address and I'll get them sent.
Donnie
2011 F150
32 Ford Coupe
1985 Mustang 10.50's 1/4
1997 F350
If it wasn't on 8 Track it's not worth listning too
jkimbrel65
Post by jkimbrel65 »
Got a painless one in the uni and an ezwire in a duster.Will never use factory harnesses again :D
I tried being normal once...
johnny
Post by johnny »
:iagree: ive got ez wiring in both my 55's did them both myself took about10-12 hours
john
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
