Inside frame rail tank
Gnant
Post by Gnant »
Does anyone have an inside the frame rail tank and shield from say a 67 or 68 camper special. I am looking for an aux tank to install on my 65.
Sean
rhotford
fuel tank - center frame rail
Post by rhotford »
Hi
I found an article on the net that had detail plans to install an new fuel
tank in the rear of the bed. using a new mustang fuel tank.
the plans showed how to make a frame to hold the tank and how to
make the fill cap at the rear of the bed.
I dont have the site with me now but did print it and can get later.
go luck,
Rhot ford
by year:
SOON TO COME - 52 panel(351-c)/4x4
63-unicab/swb-one owner/low mile orig.
72 f-250/77-150
82 swb step-new 302 lgblk
Re: fuel tank - center frame rail
rhotford wrote:Hi
go luck,
Rhot ford
actually you do have the site with you, its right above the posts @ FordTruk.com Home
heres the link to the article by our own Uncle Skip
http://fordtruk.com/index24.html
jecsd1
Post by jecsd1 »
http://fordtruk.com/forums/viewtopic.php?t=6123
another idea. I think this is what I'm gonna try. It depends where you want to fill. Good Luck.
DCarr
More gallons.
Post by DCarr »
Great article by Uncle Skip. Thanks for pointing out that link. If you need more fuel capacity you could substitute an "R" model shelby tank (30 gallons plus). I think Tony Branda has repops. Might be pricey and I don't remember if they have the sender hole.
johnny
Post by johnny »
i think modern chebby tanks sitting in bed would do just fine nothing wrong with that hey Dave ( couldnt resist my friend) hurrah.gif
2) 55 f100's
2) 65 f100's
and all the other ford trucks my wife doesn't know about!!
jecsd1
Post by jecsd1 »
I'm all about the best part for the application. Not too worried what a catalog says a fuel tank is designed for so long as it serves the purpose
DCarr
Post by DCarr »
Thanks , Johnny; you,re giving away all my speed secrets.
Gnant
Post by Gnant »
That was a nice install with the mustang tank. I was hoping to put a door on the bed for the filler port and use a second tank from a Camper Special. Haven't seen anyone do this, so maybe I'm barking up the wrong tree.
Johnny Canuck
Post by Johnny Canuck »
you mean like this?
[albumimg]1512[/albumimg]
[albumimg]1511[/albumimg]
[albumimg]34[/albumimg]
Bronco 2 gas tank, 78/79 F100/Bronco gas door, '72 F250 bed bridge
bluebolt
Gas door
Post by bluebolt »
Johnny Canuck wrote:you mean like this?
When I first saw that gas door I thought it was a 79-93 Mustang door. I have had thoughts of using one of the Mustang doors and even cut one out of wrecked 89 5.0 I scrapped. Now I just need a truck to use it on LOL.
Johnny Canuck
I think they are very similar. I know the F-100/Bronco follows the body lines of the slick almost perfectly.
Rosati
Post by Rosati »
This is what Skips idea turned into for me. Except I used a 1970 Cougar tank that has a 22 gallon capacity. Same as the Mustang take except its a few inches taller and it even still fit inside the frame rails and under the bed.
[albumimg]3193[/albumimg]
I hate Message Boards.
blackagatha
Post by blackagatha »
haha Rosati, I just realized what your trailer hitch used to be.... Didnt like it as a transmission crossmember, eh??? that's kinda cool.
Truckfarmer2
Post by Truckfarmer2 »
email me, I may have one I removed from a 1970 years ago.
Rosati
Post by Rosati »
blackagatha wrote:haha Rosati, I just realized what your trailer hitch used to be.... Didnt like it as a transmission crossmember, eh??? that's kinda cool.
Yeah, I had to make a different one since this one wasn't deep enough to clear the exhaust. If I mounted it over the frame rails, trans was too high and if I mounted it on bottom rail, the trans was too low. Here's the one I made.
I used the old one to make a light duty reciever until i get the bed on.
[albumimg]4607[/albumimg]
