overdrive automatic in y-block 292
don luster
Post by don luster »
Is there any way to install a later od automatice transmission to a 292 y block ford engine? Could a machine shop mate the two together with a machine plate and spacers between flex plate and torque converter, If they were machined to the same thickness as the adopter plate? If no one can come up with a way to do this what about using the gear vender overdrive adaptor and go with std transmisson . the problem is I just can't cut up a choice floor board to put in a overdrive stick shift transmisson. I want to use the column shifter but want overdrive? Rack you brains and help me out. Thanks you for reading and thinking and trying to help. If you can think of an transmission that might work this way please suggest the model etc. This will be for a 56 ford 2door sedan car. If there are other web sites that might help please list them.
Don luster
Don, you might look here
http://www.y-blocksforever.com/
DCarr
Post by DCarr »
Hey, Don anything is possible with enough time & machinery. If I had some drawings or templates I could probably come up with something. I'm a machinist & have access to the proper equipment.---David.
don luster
Hey gang thanks for that great information.
Sorry i didnt read it prior to talking with my brother-in-law the machinest about this. He said to bring me the 292 std bell housing and the transmission case and he could maching a plate to adopt it toghether and then probley mach out some spacer for the trans flex plate or a ring for the 292 crank base on how much distance it would need to take up form the plate adapter. The problem will be to find a starter that will work on the adaptor or block that will match the ring gear of the flex plate. So i may match this up with a thin sheet of plywood just to work out the clearance etc. Thanks again If this works out anyone would like a copy of this adaptor let me know. My B-I-L is the best on doing things for free when he very very busy. He like to play around with these kind of thing but never has a good excuse to do so Thanks for your help. Don
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
This company sell an adaptor, look down about 3/4 of the page at #56Y
http://www.redrider.us/aod_parts.htm
and this one for manual RM-8055
http://www.quicktimeinc.com/products.html
Lonnie
jakdad
Post by jakdad »
Looks like a full balance job would be in order. Harmonic balancer through flywheel...................................
Jim
don luster
Are you saying the 292 engine is external balanced or that changing all these items would help if they were balanced? The flex plate should already be balanced. If the spacer for the crank flange was machine from good steel it should be real close to being balanced. I got my truck engine completely balanced at local machine shop and it was not a bad price and i well pleased with the performance of the torque of my horse trl pulling 3/4 ton truck. Thanks again Don
don luster
Hey Skip -- The car
Hey Skip I guess you have noticed about what i'm thinking about doing to the 56? Paint may be black or red. 59 Buick tail lens the front and rear bumper will have the bumper guards removed. Disc brakes upfront I went and found a 67-69 granada v8 but they were not cheap. They wanted to sell me the rack and pinion along with all the parts that I needed I will keep looking for a better price. 40 per spindle and 15 for the tie rod end each. I will call some more wrecking yards nextweek. Maybe upholstery the car in leather for the seats in red The rims will be powder coated red with chrome lug nuts and maybe small moon caps or with the period correct flippers for the hub caps. I will either use a 292 ford y block with a aod trans if it goes auto or three on tree with and overdrive . Hope this will not make you sad about the car. Don
fmartin_gila
Post by fmartin_gila »
Don,
Don't know if they are still around, used to be a company either in Minnesota or Wisconsin with some kind of Norwegian name that made adapters to put autos behind most any engine. Also, they made controllers so you could use a computer controlled tranny behind a non computer engine in a non computer car. Seems as if the name started with Nor???? or Lund????. My rememberer has just got too short these last few years.
Fred
don luster
Thanks Fred but I found that co searching on the computer. they have what I need but they are way out of my budget. My brotherinlaw will make one in the machine shop if we can figure out what starter will work on the adaper. maybe someone will have their adaptor and be able to tell me what starter will work. don
36truck
Post by 36truck »
Don use one of the new style of mini starter from a 460 ford. Then while you make the trans adapter build in the mini starter.
Tom Williams
