Put your Thinking caps on Trivia Time
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
:roll: :hm: Ok since no body caught do it in a separate Topic,, What does the B-Model Macks and Ford have in common :?: What era of Fords am I talking about :?: and what did Ford do in the 40's ,50's, 60's :?: :hm: bang.gif your thinking caps on
12649
36truck
Post by 36truck »
I think I need a bigger thinking cap because I lost as to what you are thinking. :D
Tom Williams
6166 Junkyard Dog
ok its a 3 part ?
# 1 B-Model Macks and Fords have what in common
# 2 on these models what years are involved
# 3 what did Ford do in the truck industry in the 40's,50's,60's
So its 3 ?'s,, once you get the 1st? all the rest should fall in place
12649
well as to what ford did in the 40s they made stuff for the military and if they were still doing that they would not be near broke. no new cars from 43,44,45 and 46 yet they did just fine.(gm and chrysler did too)
as to the mack only thing i can think is they used the same frames and axles as the fords.
its early and i only had 1/2 cup of java so thinking cap has not really warmed up yet.
6166 Junkyard Dog
Ice is warm,, not hot but heading in right direction,, hope you don't hit a snowbank and get cold
12649
don morris II
Post by don morris II »
the only thing i can think of is ford made a model B also ? :dontknow:
FORD, FAST, FLYING, FIRST, ALL START WITH F IS,NT THAT "SLICK"
6166 Junkyard Dog
Don is on the right track,, in the Ford History Book, Ford Designed the B-Model Macks example look at both of the rear cabs, door post way the doors open and you will see how close they are ,, also the early truck Mfg's did not have there own designers so Ford lent there men out to design a lot of the a early trucks in the 40's to early 60's
12649
