HELP engine
don luster
HELP engine
Hey gang really want to use the 292/312 engine in a 56 but after looking at the prices of rebuilding the engine I probley will wait for a while before going this route. I also want an aod overdrive transmission. SO I need a year or make of a small v8 engine that I can bolt the aod transmission to without buying an adaptor. I want good gas mileage that is very important but would like the smoothness of a v8. Is there a 302 or older 289 that would work. I'm real green and dumb on this part of the auto world. I don't want the expense of trying to use all the computer crap. Is this a reality? I want to drive the vehicle and we all know that fuel will go back up when they can put it toooooo us. If I could find all the parts for a std overdrive I would not mind going that route if I could find an engine that will run for a few miles of the 272-312 ci I don't want a floor shift in the 56 ford car floorboard. But that bring us the problem of the car would have to be converted to clutch pedal etc. I guess that would be hard to find on a poor mans budget. Any and all coments would be welcomed. If I need to give some more thought of what I want please jump on the wagon and ask me. Thanks for your thought and suggestions. If you know what the going price at U Pick yard for the engine your recomend then please list what your area is charging Don Luster
don luster
don luster
don luster
I found a 73 v8 maverick and I have two questions for you'll Will the spindles, hubs, rotors etc work on a 56 ford fairlane. I know about the Granada and Monarch that they will. This one has the 11 rotors. maybe this car would also have the aod??? How can I tell? Are there some codes on the vin number etc? Thanks for sooo many questions. Don
Don, you Fairlane is pretty heavy. Find a 5.0 Mustang with an auto tranny for a donor. It will have the roller cam 302, more torque than a flat tappet engine. The AOD in the Mustangs has more clutches - stronger tranny. This combination has EFI but a non computer tranny, you will only need to swap out the intake ad an electric fuel pump and get a TV cable from Lokar - have the TV cable adjusted BEFORE you drive it. If it's set wrong the tranny will eat itself. The headers on the 5.0 may even work in the car - factory block huggers really. Puts you one up on your Y block/AOD too.
