steering wheel
texas trux
steering wheel
ok guys recently bought a steering wheel for my 65 from the bone yard but having som trouble getting the old one off. should it slide off with a little held frm a can of WD40 and a hamer. Just wanted to ask before i tore some thing up.Ithink
NG3
there are 'other ways' to pull them
but a puller is the right way
Besides, the type that Bill W posted, can be used to remove harmonic balancers from crankshafts, too. Two tools in one, gotta love that!
Welcome aboard.
And, the puller will probably NOT come with the correct threaded bolts that go into the wheel.
Best I can recall, the correct size is 5/16 NC, BUT CHECK THAT FIRST WITH A SEARCH, AND MORE IMPORTANTLY, WHEN THREADING THE BOLTS IN, DON'T FORCE THEM.
The steering wheel metal is either pot metal or I am sure someone will again correct me that it is aluminum. In any case, its NOT steel, so you can force the wrong bolt in there pretty easy.
Don't ask how I know all this........
the threads in the steering wheel for the puller are 5/16-24 fine (NF).cdherman wrote:And, the puller will probably NOT come with the correct threaded bolts that go into the wheel.
- Uncle Skip
Texas Truck. Where are you located. Some one, some where is close to you. There is a big group in Houston, San Antonio, Austin, DFW, and even in east Texas. If you're here in H-town, you can borrow my puller and we can probably get a few guys to come help you with the truck.
Let us know.
U@ss technically in Pearland.
Let us know.
Garbz
Looking for the correct bolts?
Same thread is used to bolt the fan to the water pump. Grab a set from a fan that has a spacer and they'll be long enough to do the job.
i have had some that have been stuck on badly even with the correct puller being used. you can put your knees under the wheel and pull up with your knees and then hit the puller with the hammer once it has tension onit. it should pop off. it took me several hits with a hammer to do the last one. it was stuck on there badly. make sure and retighten the puller each time you hit it with the hammer. and make sure the bolts go all the way into the holes.
texas trux
thanks
You guys rock! Thanks for the tips and yes i'm ussualy the cat that does it wrong the frst time. LOL! THANKS AGAIN GUYS. Buy the way really killer 66 in new CLASIC TRUCK rag
NG3
Garbz
