motor problems
62galxe
motor problems
Post by 62galxe »
well i know why the motor wont make a full rotation.it had some water get into the center cylinders on the passenger side.rusty.removed the heads and pan today.guess i need to pull the motor and tear it apart. :cry: this is my 292.
kenny
1963 uni PATINA BLUE
1965 short bed
Phil
Post by Phil »
I hate that feeling :(
maybe the head gasket was blown between those 2 cylinders and thats where the water came from.
62galxe
Post by 62galxe »
well there may be a little good news anyway. the heads are ECZ-G which are the big valve small chamber heads.they were used in 1957.
kenny
1965 short bed
jakdad
Post by jakdad »
ICEMAN6166 wrote:maybe the head gasket was blown between those 2 cylinders and thats where the water came from.
:iagree:
Very common problem on the Y-Blocks. I finally stopped it on our 312 stock car engines by using Victor big bore gaskets put on with K&W Coppercoat.
Jim
62galxe
Post by 62galxe »
guess ill go look at the gasget again
kenny
1965 short bed
62galxe
Post by 62galxe »
motor turns now. beat piston to bottom of cylinder with bfh while somebody is tugging on breakover bar. insert flapper wheel in die grinder and hone cylinder. :twisted: rust is gone.sure makes it easier unbolting rods when the crank turns.
1965 short bed
62galxe
Post by 62galxe »
well 1 head is cracked. found another head on the yblock forum. there is some good people over on that site also.
kenny
1965 short bed
