62 unibody build
twistedfreak
62 unibody build
Post by twistedfreak »
""WE THE WILLING, LED BY THE UNKNOWING, ARE DOING THE IMPOSSIBLE FOR THE UNGRATEFUL""
twistedfreak
heres the latest to the slick
twistedfreak
and some more picks of the work on the slick
61 Merc
Post by 61 Merc »
I had mentioned earlier that the sill plate I got from Carpenters is shorter than the original Looking at your latest pictures I notice that your sill plate is shorter than the original. When I saw this I had to go take a picture of a set.
[albumimg]5131[/albumimg]
[albumimg]5132[/albumimg]
[albumimg]5133[/albumimg]
The ends do add an extra amount of support.
Dean
61 Mercury SWB Uni - Project
63 Ford SWB Uni - Parts truck
twistedfreak
so whats the fix buy another one and cut and add or can you get the longer ones from somewhere else let me know and ill hold off on welding them up just yet
61 Merc
Post by 61 Merc »
What am going to do is make the ends and weld them on, as the ends provide a lot of support to the step. The rear actually is spot welded on three sides and the front is spot welded on two(?) sides with the third side being the lower anchor for your front fender.
I will extend the new ones, and then repair the old set as I will be needing both sets for my uni's. All that needs repair on the old set is the front where the fender attaches, it needs a 1" flange welded in where it looks broken off the side as displayed in this picture.
[albumimg]5134[/albumimg]
twistedfreak
ok i got you now they just stopped it where the door meet the frame and didnt extend it past under the front cab mount i can make that piece and the rear and weld them on for better support is that what your talking about
61 Merc
Post by 61 Merc »
Thats it, and you might want to weld it to the rear panel as there isn't much support on the outer edge of the sil plate. What did you do about the torque box behind the cab, I know I don't have any info on it other than I know it is an integral part of the body.
Keep up the good work and keep us posted.
Dean
twistedfreak
i made a rep. to the factory one out of 14 ga and welded it solid to the back and the bed sides and made the floor fit flush with the frst ill try to get some pick of it up tomorrow or sunday
DCarr
Post by DCarr »
Looking forward to it. Have you done any more work on the front suspension?
twistedfreak
not yet concentrating on the body right now and ill get back to the frame when the body is done but the only thing let on the suspension is the track bar really
twistedfreak
heres some updated picks of the bed area and tomorrow when i get my door piece back from my friend ill post the picks of it installed in the truck.
Garbz
Post by Garbz »
Nice replication of the Torque Box.
You may want to article that and post it with dimensions.
Looking good.
Garbz
twistedfreak
can do that garbz its a little heavier than factory it 14 and not the 16 or a little thinner than what the factory uses
Garbz
Post by Garbz »
Man, You have your hands full. That is a shitload of work my friend. Good job.
Garbz
twistedfreak
a lot of welding
twistedfreak
some more picks of the build heres what i got done tonight
heres the torque box welded in place with the bracing for the floor and all
underside of the torque box
and the door jam with the freshly sandblasted corner
DCarr
Post by DCarr »
Nice-should be stout. Are you migging or tigging?
twistedfreak
right now mig but ill tig the frqame and the body work but the heavy stuff gets mig
Garbz
Post by Garbz »
Before you full weld the bottom sills mount a door and check the opening. I had one grow too wide on me on a project and i had to take out a 1/4 inch.
Just a little insurance.
Garbz
