1966 f250 ford truck with 8 foot bed 130 inch wheel base
ermcswain
Post by ermcswain »
I want to transfer my 1966 f250 cab and 8 foot bed to a late model ford 4wd chassis. Does anyone have any experience are knowledge of possible ford 4wd year models that would permit this switch.
65TremecGT
Post by 65TremecGT »
There are several on the board who have swapped to up to 1979 4x4's as they are similar.
Welcome to Slick60's!
Anthony
Post by Anthony »
this is my '66 on a mid 70's highboy chassis.f-250 4x4....how I got it less bed..[albumimg]4908[/albumimg]...parts truck..[albumimg]4909[/albumimg]...chassis cleaned and painted..[albumimg]4263[/albumimg]...reassembled for motivation..[albumimg]4230[/albumimg]...back into the garage..[albumimg]4304[/albumimg]...how she looks now..[albumimg]4882[/albumimg]..every thing seems to bolt up just fine although I think the gap between the cab and bed is a little wider. cab mounts line up and the radiator core support lines up. I did have to trim a small piece of the drivers side inner fender off to clear the steering box. you can pick up a mid 70's chassis fairly cheap up here in West Virginia. the only problem I have found to have but am not ready to tackle yet is going to be the steering column. will need a mid 70's column and the mount, according to these great guys on this site, is different under the dash but can be modified to work. these slicksters are a valuable asset to any 61-66 slick project you will have. luck.gif with the '66 and remember...pictures,pictures, pictures......Anthony
STOFFER
Post by STOFFER »
why not grab a tranny and transfer case, and front suspension from a 1/2 ton 70's ford and then use the chevy dana 44 hubs to keep the coils springs in the front and the 8 lug wheels
I miss my slicks
in2hotrods
Post by in2hotrods »
STOFFER wrote:why not grab a tranny and transfer case, and front suspension from a 1/2 ton 70's ford and then use the chevy dana 44 hubs to keep the coils springs in the front and the 8 lug wheels
Although that sounds like alot of work it is probably much simpler.
