knobs for accesories
willy12844
I have a 65 F-100 slick. Im in need of a couple knobs that work the lights wipers and the other accesories. Tjey are black tapered with a white insert in the end. They have a spring type metal piece that grips the shaftwhen pushed on. I could use 2 but 1 would get me by. Please let me know if you can help.
Thanks,
Thanks,
I have a 1965 short bed step side F-100. It has a 302 V8 in it.
Dennis Carpenter Reproductions sells New ones.
- ezernut9mm
and they are cheap. like eight to 15$ depending on what knob you need.
blackagatha
not even that much... like $3.
but they charge MIN $10 shipping (ripoff), so you'd be stupid to place an order for just that.
I like the DC knobs though. The inserts dont yellow nearly as bad as the other companies, and they have an Allen set screw instead of the spring clip that used to pop off every time I pulled for defrost.
- stronger66ratfink
you know you just have to find a "used" set, clean um up, a little paint and some marbles work great
[img][img]http://img1.uploadhouse.com/fileuploads/3453/3453721dd1ce67cd93f59af4eb02bdcd7699b47.jpg[/img][/img]
Wow - CLEAN!
Wow - that has to be the cleanest slick cockpit I've seen in a while. I think I could shave in the reflection from the horn ring.
Makes me want to clean up my cab - but then I'd have to start with a shovel, then the leaf blower and the pressure washer<g>
thanks for posting the inspiration!
Doug
Doug
I also once used drawer pull knobs - there are lots of styles that make good dash knobs.
1.You take off the old knob.
2.Measure the shaft and trim it a little so the new knob will fit the bezel (the depth of the hole in the drawer pulls is shorter than the dash knobs).
3.Thread the shaft with a 8/32 die.
4.Drill & tap the knob for a set screw if you like or use a 8/32 jam nut on the back.
I found a little of the non permanent Locktight sufficient though.
Sorry no pics and I don't have that truck anymore.
As far as the inserts for said factory knobs, I tried cutting a circle from the top off a Wimbledon white touchup paint from Duplicolor....I think 5/8" diameter (verify this yourself). Worked out good, only slight difference in color from remaining factory inserts. Due to the shape of the spraycan top, also has a slightly concave shape when installed, similar to factory inserts.
Anthony
Anthony wrote:I thought ?MARBLES?but it looks like it turned out real nice. remember to make mental note of marbles...
...Anthony
at least i would know where my marbles were when the wife asks me if i lost them and could say
"no, they are in the truck"
blackagatha
- bobenhotep
i was going to put pieces of glow in the dark plastic in mine...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
"The Iron Rhino"
-duraspark II/ HEI
Garbz
- stronger66ratfink
didn't mean to steal your post Rick,
with the marbles!
and chrome horn benzil!
took the marbles out of my wife's decoration box and if she had of had pearl that's what would of been in there instead of burgandy, you'd be surprised on how many people have ask me if they light up? Horn Benzil came with the new steering wheel, that is after I paid them big bucks, got to love that imron paint when it comes to shine, close up shows that I did not spead that much time to detail in certain places, got to show everyone the new console I built out the one there, much better.
OK Rick get them nobs!
with the marbles!
blackagatha
actually, no. there are 2 styles.Garbz wrote:Rick all made the nobs... DC resells them. and they are all allen head type. Garbz
there is the allen set screw type, then there is a thread-on type.
The allen is used on the heater control, wiper, and THEIR repro choke cable
The screw on is used on factory air vent knobs and factory choke cable. (these are originally knurled shafts with plastic knob molded on. They have you run a die over the knurls, makes for some NASTY looking threads but they work fine
