Finally got the frame and engine back home. I'm gonna use the bed to make a trailer to pull behind the '66, disc brakes from a '73 F100 are under there, too. Oh and that's my nephew, helper and partner in crime.
Doesn't look too bad for being under a tarp out in the yard for the last 10 years.
No good. And to think my dad said it should be fine to just run like it is.
I mashed my wittle thumb.
Pistons are already .040 over.
I knocked the pan of coolant over.
Crank has been turned .1010.
How do I get rust out of the water passages? My dad said something about running it for break-in, get it good and hot and then drain the coolant, fill it back up with water and vinegar and let the vinegar clean it out, then drain and refill with coolant. Anybody heard of this?
'66 F100 --
'78 Bronco --
