352FE with cruiseomatic to 4 speed
rider307g
Post by rider307g »
OK, I tried to do a search, but couldn't really find what I was looking for. I have a 352 FE that I would like to run the 4 speed on but need to know if anyone has done it and how difficult is it? Not only the trans, but the clutch pedal assembly as well. Am I better off just changing to the C6? I think the manual trans would be a lot of fun to drive.
Life is too short to drink cheap booze.
f100matt
Post by f100matt »
Well, my truck was originaly a 3 on the tree, the po changed that to a automatic. When i installed my four speed i had to cut a hole in the transmission mound for the shifter and then find a cover. Then you need to replace the brake pedal bracket and put in one with the clutch pedal (I have a clutch/brake pedal and bracket for sale if you decide to do the swap :wink: ) Then you will need a clutch, flywheel, and linkages, it is not a very had swap because all the stock bolt holes should be there, its all fairly basic stuff, hard thing to screw up in my opinion, go for it! 8)
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
DCarr
Post by DCarr »
You are right-manual transmissions(4 speeds & up) are a blast to drive. When I'm too old
to row a shift handle,just shoot me & put me out of my misery! :lol: There is no feeling
quite like a perfectly done power-shift. :)
