Carburetors: Manual v. Electric Choke
jacobd
Post by jacobd »
What is the difference?
Which one goes in my truck?
36truck
Post by 36truck »
Electric Choke means that electricity makes the choke work. Manual means that there is a cable that you move to make the choke work.Your dent side truck would have a place to get the electricity from to make it work.
Tom Williams
jacobd
Post by jacobd »
36truck
Post by 36truck »
I'd pick the smaller of the 2. For a truck you won't be reving it up. Be lucky to see over 4500rom so no need to have a big carb on it. A 600 or a 650 would be big enough.
Tom Williams
jacobd
Post by jacobd »
So maybe step it down a little to this one?
http://store.summitracing.com/partdetai ... toview=sku
36truck
Post by 36truck »
That should be just fine. What carb is on there now?
Tom Williams
jacobd
Post by jacobd »
I really don't know. I'm thinking the standard FoMoCo. I can go check at lunch. Should I wait to see what is in there before ordering the new one?
36truck
Post by 36truck »
I would check it out first & see what manifold you have. But the carb will work or can be made to work.
Tom Williams
jacobd
Post by jacobd »
Tom, when I buy the carb will it come with gaskets and stuff or do I need to buy them seperately? what about a heat shield?
36truck
Post by 36truck »
Not 100% sure on the gaskets I would think so but. Would not come with a heat shield can't say as if I've see one.
Tom Williams
jacobd
Post by jacobd »
Great. I'll get gaskets too. I'll likely be changing the manifold soon enough anyway. Might need the extras.
Thanks for all your help.
Jake
