Thanks she is all factory except for the headers, cherry bombs and back bumper.
1966 Ford F-100: second year of the "Twin I-Beam" front suspension system where the two front axles work independently to absorb road shocks. It also holds wheel alignment which reduces tire wear. In combination with the new Flex-O-Matic rear suspension which adjusts spring stiffness.
F100 - 1/2 Ton
Wheelbase: 115 in / 129 in.
GVW 4x2: 4,200 - 5,000 lbs
Tires: 7.75 x 15
Engine: 352 cid 8 cylinder
Transmission: 4 on the floor with First gear Garnny
Assembly Plant: Kansas City, KS.
