need some guru advice
I just bought another 66. It's got a 390, 4-speed manual, 9" rear end and has air conditioning in it. It looks like all this stuff came standard, but I haven't seen anything that says 390 came in these. I do know that 352's were stock. Can anybody tell me what motors came in these or guide me to a place that will tell me more about this particular truck.
Lane
Lane
A happy life is a simple life.
- ezernut9mm
yep, 352 through 67, then the 360 in 68.
The 352 is an often propagated and very wrong rumor - ALL FE powered Slicks had 390s.
On the same note - ALL Y block powered Slicks had 312s too.
- ezernut9mm
exactly.Greg D wrote:The 352 is an often propagated and very wrong rumor - ALL FE powered Slicks had 390s.
Thank you for your replies. I have another question for you. I'll be rebuilding the 390 that is in the truck currently. I teach at a local technical college that has an automotive program and they will be using it for one of the student projects (but not until next Fall). I have a newly rebuilt 351M that I have in my parts truck (66 F100). Can anyone tell be me if I can bolt up the 351M to the original manual 4 speed tranny in the 65? I can pull the mounts, etc. to mount the motor, but I'd like to use the 351m until I get the other done (for about a year). Is it just a matter of finding the right bell housing and if so, what am I asking for when I look?
I'm hoping these questions aren't too dumb. I've done some restores, but mostly bodywork.
Lane
Lane
blackagatha
LOL, good luck trying to use the 351 as a temp...... The 390 is an entirely different beast.
Different motor mounts, different transmission bolt pattern to almost anything else ever made. I guess you might find the right bell, good luck....
FE is the motor designation.... Ford-Edsel. 332 I think, 352, 360, 390, 410, 427, 428 are all FE's.
Oh, I totally agree on keeping with the 390. I was just trying to buy some time. I've actually got some great punch out of my 351M, more than I thought, but it took some special doing (electric fans, shaved heads, some help from Edelbrock from the motor up, etc.) I'm excited to see what this 390 will do. Everyone's telling me it's a powerhouse in comparison. Thanks for your help. Nice truck - dig the flat black.
- ezernut9mm
i think the 351m uses the windsor bell housing and engine stands, so you'd have to change those.
Ezernut,ezernut9mm wrote:i think the 351m uses the windsor bell housing and engine stands, so you'd have to change those.
If you are referring to the 351W engine as the Windsor, then nope, I believe the 351M/400 uses the same bellhousing as the 460 engines, not the 351W engine.
There were many late 70's trucks & Broncos equipped with the 351M/400 engines and a manual transmission as well as the 460s in the '70s & early '80s - mainly in F250s/F350s.
However, around my area, I'd have to search high & low to locate one. I would guesstimate that the majority of these trucks were equipped with the C6 automatic transmissions.
I have no guesses on interchangeability regarding which engine stands/mounts to use with the 351M into a '66 F100.
Lane,
I wouldn't be to quick to start locating 390 parts....
I suggest you pull a sparkplug and do a cylinder stroke measurement to confirm it is a 390 -- and not a 352 or 360 engine.
Although many parts do interchange, I'd still want to KNOW what size engine I'm truly building first.
IMHO, if I had a 351M rebuilt and just sitting idle in a parts truck, if I could make the swap without too many issues with clutch linkage, bellhousing, motor mounts, etc., I'd seriously consider putting it in your new-to-you '66 and leaving it in there. Sell off the parts or junk out whatever you can from the tired FE engine that came with the '66 truck and never look back!
Good Luck!
BarnieTrk
- ezernut9mm
Yes 351M/400's use the 429/460 Bellhousing bolt pattern. They do however use the 302 Frame mounts. If you can find a 77-79 F150/250/350 2 wheel drive with a 302-351M/400 they will bolt onto your cross member.
This will help you out as to what is what on the perches
http://www.fordification.com/tech/engine-perches.htm.
Tom Williams
dont be afraid to use the 351m. i just finished my 351m with 70 4v heads, price motorsports adapters 4v wieand tunnelram a pair of 1850 holleys, pertronix ignitor 111 module lunati voodoo cam, lifters and push rods, dynos at 685 hp at 7000 rpm and 567 ft lbs at 5600, it sounds like it would be expensive but the biggest price was the heads at 500 bones, all other parts were used execpt for cam and valvetrain. all for about 2000 grand and some patients to look for the parts. good luck on the build
blackagatha
ronk16 wrote:dont be afraid to use the 351m. i just finished my 351m with 70 4v heads, price motorsports adapters 4v wieand tunnelram a pair of 1850 holleys, pertronix ignitor 111 module lunati voodoo cam, lifters and push rods, dynos at 685 hp at 7000 rpm and 567 ft lbs at 5600, it sounds like it would be expensive but the biggest price was the heads at 500 bones, all other parts were used execpt for cam and valvetrain. all for about 2000 grand and some patients to look for the parts. good luck on the build
685 HP for 2 grand?????? wow, I need to start taking lessons from you.....
