rusty cowling
rctcomp
rusty cowling
Post by rctcomp »
I cut some rust out of the face of my cowling and found this behind it.
How do I fix this?
My first impulse was to slather it with JB Weld but I'm not sure if that would hold up very long.
Welding a patch in that tight a space is beyond my meager welding ability.
Any ideas?
Jeff
Max
Post by Max »
Looks to me like you're going to have more cutting to do. Open up the top with a clean, square cut like you just did so that you can access the rot on the inside. Cut that out, replace it and then weld the top back on, then the front.
Bad news is it'll be a bit of work but not too bad. Good news is you can definitely treat the whole inner cowl while you have it opened up.
Rusty 63
Post by Rusty 63 »
-or- open up the top to clean & treat the whole cowl - then weld it solid with a patch panel & stop the leaks forever! ;o)
I know I'm sorely tempted....
olliesshop
Post by olliesshop »
I agree with Max that welding is the right way to go as a first choice.
Max, what do you think about brazing the holes shut. I've been using that technique on pinholes on a bunch of Ford air cleaners I'm doing for a friend. It works great for pin holes since it doesn't melt the thin good metal away, like my MIG welder will (even at it's lowest setting), but those holes look a little too big. :hm:
Tim - 1961 F250 Uni
Brian Taylor
Post by Brian Taylor »
If not fixed right that will let water into the cab and start more rust.
Agree cut the top clean, weld in a repair piece and then weld your way out coating everything too.
1966 Ford F-100 LWB 300
Max
Post by Max »
My take is rust = cancer. It has to be removed or it will come back and haunt you another day. In an area like this, just go through the trouble once and be done with it. Even if you can braze it, it's still a lot of work and would just hate to have everything finished and painted and a year later see bubbles inside that cowl.
Tim, the brazing that you're doing on the air cleaners sounds perfect though!
rctcomp
Post by rctcomp »
I would feel better knowing it was done right.
I'm a little nervous about cutting the top of the cowl though. Not sure how good it will look after I glob it back together.
should I cut the yellow line or the red?
Which is easier to weld back together?
Jeff
Max
Post by Max »
I'd definitely try and avoid cutting the red. I think you'll have enough room to work within the yellow cut-out. IF you did have to cut out the top vents, I'd almost consider doing the whole thing or find a way to limit any distortion when you put it back.
Anthony
Post by Anthony »
definately the yellow... the red would be hard to put back without any distortion... like Max said... good luck
Max
Post by Max »
Oh, and don't cut an inner corner, cut the top outer corner right above your yellow line. Much easier to weld and dress afterwards (ie. grind smooth). If you cut the inner corner where the yellow line is, your weld will have to sit in that groove and unless you're a top notch tig welder, difficult to make look purdy afterwards!!
William-in-St George
Cowel rust
Maybe blast or grind off as much rust as you can then cut a nice patch from 12 gage and glue it in place with body adhesive. No distortion and no leaks. Seam seal it all up and you are good to go.
William-in-St. George
dotcentral
Post by dotcentral »
I didn't have to go through that, thankfully. But to keep it from happening later on I used this stuff: http://www.eastwood.com/review/product/ ... egory/235/
It appears to be an etching primer with "other ingredients" added. I bought 3 cans, but only needed 1. I sprayed, while pulling the tube out. Heavy coats, instructions recomend that the stuff should drip out drainage holes to insure good coverage. Before I forget, I masked off the top of the cowl, to not get overspray all over everything. I got two coats out of one can. I hope I got it well applied, has to be better than what was there before.
Good luck with your repairs.
here are some inside views of the area.
i myself would try to cut the whole section out and weld back in along the top above the red line and below the lip.
i will cut and sell entire sections of metal to your measurements, i do this all the time.
jwh f-100
Re: rusty cowling
Post by jwh f-100 »
rctcomp wrote:I cut some rust out of the face of my cowling and found this behind it.
How do I fix this?
Any ideas?
Cut it all out & fabricate a flip up cowl vent!!! :rocker:
Jason
Beer will change the world.
I don't know how but it will.
Re: rusty cowling
jwh f-100 wrote:Cut it all out & fabricate a flip up cowl vent!!! :rocker:
no need to fabricate, just cut one out of a slick school bus.
i have actually thought about doing it.
rctcomp
Post by rctcomp »
This is what I ended up with.
Now if I could only get my father-in-law to return the welder he borrowed. :?
Thanks everyone for the help.
Jeff
Anthony
Post by Anthony »
I like the idea of the flip up vent Jason and Ice... that would be very custom and cool... :thumright:
your patch looks great... don't forget the after welding pics... :wink:
rctcomp
Post by rctcomp »
dotcentral wrote:I didn't have to go through that, thankfully. But to keep it from happening later on I used this stuff: http://www.eastwood.com/review/product/ ... egory/235/
Good idea, 20 bucks sounds like cheap insurance. Thanks.
Jeff
