First things first. I have been wanting delay wipers ever since the first day it drizzled and i flipped the switch back and fourth for a 6 hour round trip. Not fun. So while the truck was coming out of winter storage (by which i mean the pile of leaves in my driveway) i decided to put a delay box on it.
Now i have read all of the topics on here that i could find about it. But im still stuck. My first mistake is that i ordered a delay box from jc whitney
What is happening is that as soon as the relay in the delay box closes, it then will not delay the wipers. they just run as normal. I have single speed wipers with 3 wires. im colorblind so i cant tell you what colors they are. i use a test light and an ohm meter to trace wires. my wife was kind enough to label the wires on the delay for me so that i could wire it up as per the instructions. no luck. Has anyone ever added a delay box like this before or can anyone school me on how the wipers work? ( i know one is the park wire, one is the switched wire, and one makes it turn off. but im not sure how they actually work together.)
Issue number two. I have a manual 3 speed mated to a rearend with 2:50 gears that i pulled from a 75 lincoln town car. the motor is a 240 with the offy dual plane intake, a holly 4 bbl, tuned split dual headers, dual point ignition, a lumpy rv cam, and its well balanced. tons of power even with the crazy gears. however in 3 years i have had the motor and tranny split apart 5 times. two clutches, a throw out bearing, and i had to rebuild the mechanical linkage twice. The thing bucks like a mule taking off in first gear. im pretty good at getting it going smooth, but i made the mistake of letting a buddy borrow it for a parade and the clutch didnt make it 5 blocks. aside from burning out clutches the mechanical clutch linkage is getting super sloppy from all the bucking and i dont trust it anymore.
so.......will a C4 or C6 bolt up to my motor? ( and before someone suggests it, no i will not replace it with a 302. i love straight 6's ) Will a C4 even hold up to those rearend gears? I hate to change my gears because at 70mph im only turning 2grand. it cruises all day and gets 20+mpg. Would i be better of going with an older vacuum shifted AOD and dropping the rearend gears to say a 3.73? i have even debated going to a T5 tranny and doing a hydrualic clutch and figuring out a way to mount the master and slave cylinders. or should i just learn to love the smell of burning clutch?
What are your guys thoughts on these?
Thanks in advance
