show me your guages
jkimbrel65
Re: show me your guages
Post by jkimbrel65 »
Mike
I tried being normal once...
HiBoy63
Ireland
Post by HiBoy63 »
qwertyd10n wrote:Here is mine...
The two side gauges (voltmeter and oil pressure) are 2 1/16" offerings from Autometer's Traditional Chrome series... the the mini tach is a 2 5/8" unit from the same series.
Cheers,
Dion
Very nice keeps the stock look does the job. I like traditional.
1963 F250 4x4x292
1965 F100 4x4x352
1998 F150 4x4x4.6
2001 Sport Track 4x4x4.0
Heritage country Flag
Lee's 64
Post by Lee's 64 »
BlackWater......... That is a killer dash panel. I love the LARGE vac. gauges. How hard is it to find those F800's. Great job. Do the vac. gauges work good? LEE
IF YOU DROVE A FORD......YOU WOULDN'T NEED A GOODWRENCH!!!!!!!!!!
1964 Ford CustomCab Shortbed
1952 Ford 8N Tractor
2012 Ford F250 CrewCab
shocker998md
Post by shocker998md »
im not trying to sound like an ass, but theres 22 posts and one person put up a picture of the sweeping cluster like im looking for.
Any body else out there have pictures of there SWEEPING cluster? Or has everyone swapped to the round style.
Kenny
Blackwaterforge
Post by Blackwaterforge »
Hi Lee
I bought the F-800 bezel from a site member.
It was listed in classified.
Vacuum gauge works well.
shocker998md wrote:im not trying to sound like an ass, but theres 22 posts and one person put up a picture of the sweeping cluster like im looking for.
Kenny
the sweep clusters being plastic are not very easy to change from the stock configuration or even paint if your not real good at that.plus 90% of the ones i have acquired were broken cracked or deformed from sun.
replacements cost far too much so i do believe many do change to the round metal style.
i did however change my 65 f350 from round to sweep just to be different from the rest of my trucks. since its a work truck i just sprayed it with rustoleum silver and being plastic it is what it is, painted plastic
563
heres one in a parts truck i have
Sorry,
I just like showing off my gauges :oops:
I did understand what you were asking, and noted in my post that one of the members had if fact fabricated a great looking plexiglas insert, albeit utilizing aftermarket (round) gauges, I believe.
I also considered cutting out the center raised section of the sweep panel and fitting a thin sheet of readily attained aluminum sheeting with an engine-turned finish covering the original panel, including the area originally done in the imitation machined finish.
There are sweep panels which would adapt well IMO, both after-market and OEM.
As stated, my low-rider will eventually utilize a panel which is totally blacked out until the lower smooth-surface ignition touch switch is activated; then will illuminate and perform a "sweep cycle" in the manner of the Dakota VHX, and the ProSport electronic stepper motor gauges.
Thanks for the original posting, and again sorry for the hi-jacking; the multiple responses may certainly help some of us to understand what is available and being done.
qwertyd10n
Post by qwertyd10n »
Kenny,
Tom's got a nice new sweep style instrument bezel:
http://www.flashbackf100s.com/new_parts_page
Cheers,
Dion
[ Post made via BlackBerry ] Image
shocker998md
thanks for the link. Thats the flasy one that im not 100% sure if I like it. I guess Id have to see on in a truck. Anyone has some pictures of one of those installed?
Casey 65
Post by Casey 65 »
This is what I did with my guages.
"One Test Result is Worth One Thousand Expert Opinions" - Werner von Braun
chris401
Post by chris401 »
I never had the sweeper. Here is what I did in the 65 1/2 ton.
66CC
Post by 66CC »
I have one of those "flashy" repro sweep clusters installed in mine. Gauges are all originals cleaned up & detailed a bit. I like the stock styling, and it looks way better than the roached out original bezel did IMO.
BigMike
Post by BigMike »
Casey 65 wrote:This is what I did with my guages.
Looking through your album, I found what you used to pull the old ones out. :shock:
1991 Porsche 964 Cabriolet
2006 Cheby Silverado
f100jim
Post by f100jim »
Here's an original bezel I got in the early 80s from the dealer.Image And here's a repo I got off of ebay last year,but I painted the inner ring silver to match original.Image
Casey 65
Post by Casey 65 »
Don't tell the women :shock: . that's the big surprise race for the wives at Slick Stock 5!!!!
BigMike
Post by BigMike »
Installed this the other day.
Uncle Skip
Post by Uncle Skip »
Talk about a tractor pull.....
F7BIGJOB
Post by F7BIGJOB »
7897
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
Customcab4x4
Post by Customcab4x4 »
Phil
64 F-100 (on modified 79 4x4 chassis)
63 1/2 Galaxie 390/4sp.
66 Mustang
89 F-150 Lariat XLT
lo6fo
Post by lo6fo »
Blackwaterforge wrote:Image
I used a chrome cluster out of a F-800 with vacuum and tach.
i love this. i stil have the same old stock single guage cluster in the center.
64 f100 long bed 292 with a 4 speed
