65 f100 swb step side with 240 cid and 4 spd warner T-18
Hopefully you can see the degree of how the rear end and the front I beam is bent. I feel like i can fix the rear end with a little heat and pressure but i'm not sure if i should try this on the I beam. I'm not sure if this is damage on the I beam or was an alignment issue. The other I beam looks great. Looked at the past treads and didn't see any pictures to help me out.
The frame has a slight buckle to it that i've had a frame shop look at. They are going to fix it when i get the truck rebuilt so that we can get weight on the frame.
As always your help is greatly appreciated.
Going with a stock setup on the truck and cliffords 6=8 on the engine. cam, intake and headers. I'm also going to put a flame kit on the exhaust to please my son
