changing the oilpan. any wise words?
hey i am going to change the original oilpan of my '65 300 L6 to a rear sump oilpan of a '85 300 L6.
any tips and tricks?
i also have the gasket from felpro. this is a 4 piece gasket. two cork like side gaskets and two rubber gaskets. on the rubber one tranny side gasket there are 5 or 6 rubber pins (dont know how to say it) are they going in somewhere or do they need to be cut off?
any tips on how to install the gasket in combination with the silicone gasket maker?
i"m changing the oilpan to get my jag frontend installed. the original one interferes with the subframe and if i'm correctly informed the rearsump won't. we'll see.
thanks
see ya
twan
thanks
see ya
twan
Re: changing the oilpan. any wise words?
the tabs will go into holes usually in the timing cover. The biggest thing is clean all surfaces with laquer thinner before reassembly. Get rid of the cork gaskets and get neoprene gaskets. cork sucks!!!
Get all the surfaces super clean, then throw the new gaskets in the trash. RTV ultra black real thick for the end seals and a thin layer on the block and pan, then bolt the bolts up TIGHT before the stuff sets up. (you have plenty of time using the ULTRA stuff as it sets slower. Let it sit a day then it will never leak, and those gaskets won't spend the rest of their life trying to squeeze out from where you put them.
I would test fit the engine to your truck with oilpan and jag front end first before sealing it up,Gaskets aren't cheap
I use contact adhesive on cork gaskets ,they don't leak and they don't push out .
hey i found a oilpan from a partstruck (i live in the netherlands europe so it aint easy) but i got it and it was pretty rusted on the outside and inside!? so i've decided to order a new one and a oil pick up from rockauto and hope it will arrive on time.
how is it that a oilpan rusts on the inside??
see ya
twan
see ya
twan
Water in the oil?
yeah ok but this is severe rust in the upper parts off the oilpan the deep parts were nice. it comes out off a '85 f150.
i hope the new pan comes and will fit...
see ya
twan
see ya
twan
hey guy's ,
the old i beams are out off the truck and the jag is installed for now and i have to hook up the brakes and steering. all in all not that hard but more work than anticipated.
i also installed the new dorman rearsump oilpan, a great new pan and good fitting. but now my dipstick touches the cranckshaft because it sits now in the higher area off the oilpan and not in the deep area.
what to do?
shorten the dipstick so it doesn't touch the cranck but the you can't check oillevel.
or is there a relocation set or something?
thanks
see ya
twan
what to do?
thanks
see ya
twan
Twan: Find out the year & model of the donor pan, and get a dipstick (AND TUBE, if required) from that same year & model.
Thanks, why don't i think off that. it's an '85 f150 pan so thats what im looking for .
thanks again!
What a great place this is
see ya
twan
thanks again!
see ya
twan
well i'm searching for the dipstick and tube but i can't seem to find anything...
so i need a dipstick from a 1985 f150 because my old ('65) is hitting the cranckshaft.
who can help me?
thanks
see ya
twan
who can help me?
thanks
see ya
twan
check with SPECTRE performance, i couldnt find on their website but i believe they did make one
Why not have someone meassure the 85 dipstick and see if yours is to long? Im guessing the dipstick mounting location is the same in all years.
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
1998 1100 Aero (Hers)
2001 1100 Aero (Mine)
Wish List:
Win Indy 500
Ask Elvis WTH he has been
1966 F100 (Mine)
1965 Mustang (Hers)
1965 Mustang (Hers)
Wish List:
Win Indy 500
you've got a point there.
the '85 is a rear sump and my '65 is a middle sump so the dipstick is in the deep part.
now i've changed the pan and the dipstick is in the shallow part so cutting the dipstick is an option but is the reading off the dipstick still accurate?
anyone out there who has an '85 that can meassure the dipstick?
thanks
see ya
twan
thanks
see ya
twan
or find out how much oil the new pan holds, put that much oil in and make a new mark on the dipstick at the oil mark
somebody on the ford six performance site may be able to help.
http://fordsix.com/forum/
1963 uni PATINA BLUE
1965 short bed
1965 short bed
Oke, but howmuch oil has to go in the engine? i have now 5 liters in it after the oilpan change.
thanks
see ya
twan
thanks
see ya
twan
6 quarts including whats in the filter is what i have found for a 1990, should be the same for yours
And 6 quarts is howmuch liters? im having the metric system.
thanks
see ya
twan
thanks
see ya
twan
1 quart is 947 ml, so use 6 litres
