it is 19 inches long, I was going to have clearance problems with the exhaust so this worked best for me. my universal is in the cab before it goes thru the firewall. I had to fab brackets to mount it. the stock column goes all the way thru to the frame mounted steering gear-=GS=- wrote:What are the details on the IDIDIT steering column you used? How long is it vs. the stock one? Was it difficult to install, I'm about to do this with my truck as it gets the Mustang 2 cross member.
64 going down
Re: 64 going down
64 Build viewtopic.php?f=32&t=31755
Re: 64 going down
a little more progress, the new rear rims came in and working on the widened and raised wheel tubs
American Racing Torq Thrust M 18x10 6.5 backspacing 295/35/18 BF Goodrich KDW's
old wheel well out and floor modified for clearance
new wheel well inn need to make a filler panel to the bed
big ole wheel and tire fully tucked
62bigwindow
Re: 64 going down
How did you fab the steering column mounts?I am going to have the same issue with my truck.
Re: 64 going down
made the brackets and used an ididit floor mount bracket, then modified the stock column mount62bigwindow wrote:How did you fab the steering column mounts?I am going to have the same issue with my truck.
a piece or 4 inch flat bar and some angle iron. it is just tack welded now I will finish welding when I pull the brake pedal housing out to modify the pedal, I hate overhead welding. I will also use carriage bolts for a finished look.
Re: 64 going down
wow, did not realize how rough those tack welds looked. I will also remove all the set screws and drill and thru bolt the universal. I have had those back out before.
Re: 64 going down
That's what I love about the IRS - lay it on the ground but you still have a "real" bed! Nice work.
Re: 64 going down
todays update, the front air suspension is in, the truck will lay the frame on the ground but also will have 9 inches of clearance at the rockers when in the full up position.
- Sweet6T6Ford
Re: 64 going down
Ive really enjoyed watching this build come along... keep up the pictures. Cant wait to see the end result. i would like to do the irs as well but that will have to be on the next truck.
Robert
http://s1231.photobucket.com/albums/ee512/uofmfresh/
"In the silence of the night if you listen quietly you can hear your neighbors chevy rusting"-- unknown
Re: 64 going down
here is todays update, got the shock mounts made and the accuair height sensors installed then installed the front sheetmetal. I cut the radiator support from the donor Mark VIII (nice to have a donor for parts) and will use it for the radiator and condenser mounting, this will work out good. I will have factory radiator and a/c condenser with factory cooling fan. the trans cooling lines will mount without modification also. I did not realize how low the radiator is mounted in the Mark VIII, I had to remove the front crossmember but with the mustang II crossmember welded in and the frame boxed it should be fine. I will make a filler panel above the radiator.
accuair
crossmember removed
donor section of radiator core support
radiator and fan mocked up, it will use all the stock hoses
accuair
crossmember removed
- Sweet6T6Ford
Re: 64 going down
Robert
thenephilm
- 1965fordf100
Re: 64 going down
Looking great! Do you have more pics of how you did the structure for the bed floor and how it attaches to the truck frame?
Phil
Re: 64 going down
I will look for some, It is one inch tubing welded to the original bed floor and sides, the section in the rear for the fuel tank is the only part attached to the frame1965fordf100 wrote:Looking great! Do you have more pics of how you did the structure for the bed floor and how it attaches to the truck frame?
Re: 64 going down
thanks, the accuair is a sweet set upthenephilm wrote:Lookin nasty sir. I like that you are running an accuair setup
Re: 64 going down
Great fab work and thanks for the pictures
Re: 64 going down
50adrod, what height and diameter are your rear bags?
Thanks,
Thanks,
Re: 64 going down
it is on hold while I build my 54 Cadillac Limo restomod. but I will getting back to itlo6fo wrote:Any progress?
