where is that part
where is that part
not the first time, not the last
i do not know where they go
grow legs and take a stroll
a while back i was working on the uni tailgate, i took both hinges off the truck, cut one of the very rusted pins out and then i had done no more as i was busy installing the bed
since i had welded up some heavier material i had switched my welder back over to the flux wire, figured before i switched back to the gas i would do up 2 new pins and weld them in
found the still together hinge and pin
found the pin i cut out but :cussing: :cussing: :cussing: cant seem to find the other part .
looked thru everything so many times, behind, under etc.
still have not found it
so after i buy another or make the piece i need the missing one shall return
thats how it usually happens
64 f100
Re: where is that part
Post by 64 f100 »
Ice, my uncle had problems with his tools going missing while working on a vehicle. Crawled out from under a truck one day to get a tool just to see his dog run off with a wrench and go bury it.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Hey, that's gonna be my cover story. Can't blame it all on the kids anymore. Just gonna have to get a dog!
no dog in the shop but there are other critters which i have been at odds with
birds
in the spring wanted to build a nest right above the car when i was working on it
several days i knocked it down, next day it would be back.
finally i used some strong wasp and hornet foam
they did not come back
not there
moved up in the roof, now theres lots of them up there
an ongoing concert
the birds live in icemans shop :lol:
anyways one of them crapped all over my shop stool,
gonna get a slingshot
chipmunks
the little sobs are considered cute but they are a big pest
them and squirrels do most of the wiring chew damages
packrats
little buggers are actual thieves they like shiny little things as they will have a stash somewhere.
theres also the floor
only place i have not looked is in the dirt
64 f100
Post by 64 f100 »
I loose stuff all the time. Usually, I give up looking if I don't find it right away, unless it's something I have to have right then. Lost a hammer the other day, and couldn't remember when I last used it. Found it several days later setting on the 65's air filter. Usually just a matter of waiting till I run across whatever I've lost. Then put it where I can see it when needed. I have a tool box, actually several , but the tools I use stay out while I work on something. I keep what ever I need where I'm working in piles. Once I get to the point where I won't use some of the tools I put those away. Everyone has their favorite tools to use, and use most often. It's very upsetting to lose one of your favorite tools. Breaking one can be traumatic, I nearly go into mourning over those I can no longer replace. Parts are a different story. It's usually something that can't be replaced easily that drives me up the wall. Frustration sets in, and my Jeckle-Hide personality comes out. Steam comes out of my ears and lightning from my eyes. I talk in strange languages and my head can be seen spinning on my shoulders.
1961 F350
1991 Capri
2011 F250
2004 Lexus
my wife is convinced the hinge piece is right where i left it, she is likely correct but the problem is she does not know where that is either.
64 f100
Post by 64 f100 »
Wives usually have some wise remark bordering on being a smartass.
1961 F350
1991 Capri
2011 F250
2004 Lexus
