i do not know where they go
grow legs and take a stroll
a while back i was working on the uni tailgate, i took both hinges off the truck, cut one of the very rusted pins out and then i had done no more as i was busy installing the bed
since i had welded up some heavier material i had switched my welder back over to the flux wire, figured before i switched back to the gas i would do up 2 new pins and weld them in
found the still together hinge and pin
found the pin i cut out but
looked thru everything so many times, behind, under etc.
still have not found it
so after i buy another or make the piece i need the missing one shall return
thats how it usually happens
