1962 Unibody build
1962 Unibody build
Post by 6265 »
I'm building a 1962 Unibody shortbed for my wife. I've been working on it for three years. It has an Industrial Chassis Dakota kit that I've just installed. I've also moved the gas tank to under the bed, replaced the floors and other metal work. Here is a photo from when I bought it. More to come.
1965 F-100
1962 F-100 Unibody
1975 Chevy Vega drag car
1967 Mustang Coupe Vintage SCCA Race car
Re: 1962 Unibody build
Post by 6265 »
here are some other pics of it before the work began.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
Truck came with previous owners junk.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
Beginning tear down
1965 F-100
1962 F-100 Unibody
Post by 6265 »
1965 F-100
1962 F-100 Unibody
Post by 6265 »
I located another 62 unibody longbed that donated it's big rear window frame and glass along with it's doors and tail gate hardware. I also got a decent used tailgate from the Pate Swapmeet that year. This is after welding in the windows and swapping out the doors.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
the window frame roughed in.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
after blasting the cab, replacing both floors and seam sealing all the joints. still needing to replace the steps
1965 F-100
1962 F-100 Unibody
Post by 6265 »
separating the cab from the frame.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
cab is blasted
1965 F-100
1962 F-100 Unibody
Post by 6265 »
frame is blasted and is getting sealer
1965 F-100
1962 F-100 Unibody
Post by 6265 »
frame is now painted
1965 F-100
1962 F-100 Unibody
Post by 6265 »
mustang gas tank is not installed after building brackets
1965 F-100
1962 F-100 Unibody
Post by 6265 »
body now has sealer on it and PPG AEU on it's underside. time to go back on the chassis
1965 F-100
1962 F-100 Unibody
Post by 6265 »
I changed my mind on what king of truck it was going to be. wanted something that handled and drove like a newer truck. bought the industrial chassis dakota kit. it's very nice and well engineered.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
found a complete 87 Dakota at the local wrecking yard
1965 F-100
1962 F-100 Unibody
Post by 6265 »
I upgraded to the Dodge D150 rotors and will be using the Willwood calipers
1965 F-100
1962 F-100 Unibody
Post by 6265 »
installed the rack and pinion and new rotors. finally have a rolling chassis again.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
here as it sits currently. have lots of metal and body work to go.
1965 F-100
1962 F-100 Unibody
Post by 6265 »
Wife decided on colors. PPG Salsa Red and Kasmir. Fenders, lower valance, core support and inner fenders are bodyworked and painted.
1965 F-100
1962 F-100 Unibody
