1962 Unibody build
1962 Unibody build
I'm building a 1962 Unibody shortbed for my wife. I've been working on it for three years. It has an Industrial Chassis Dakota kit that I've just installed. I've also moved the gas tank to under the bed, replaced the floors and other metal work. Here is a photo from when I bought it. More to come.
- 3Gf3I63Ha5L35Ic5Hdcboa4bd6b2fb8ec1a7d.jpg (60.35 KiB) Viewed 15730 times
1965 F-100
1962 F-100 Unibody
1975 Chevy Vega drag car
1967 Mustang Coupe Vintage SCCA Race car
1962 F-100 Unibody
Re: 1962 Unibody build
here are some other pics of it before the work began.
- 3J33N53He5I15Nb5Efcbo54d593159da3116b.jpg (40.4 KiB) Viewed 15728 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Truck came with previous owners junk.
- 3G23Lb3Fa5G35H25M6cbo18e1ab8b35241574.jpg (54.35 KiB) Viewed 15728 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Beginning tear down
- IMG_0882.JPG (226.7 KiB) Viewed 15728 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
- IMG_0883.JPG (207.7 KiB) Viewed 15728 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
I located another 62 unibody longbed that donated it's big rear window frame and glass along with it's doors and tail gate hardware. I also got a decent used tailgate from the Pate Swapmeet that year. This is after welding in the windows and swapping out the doors.
- IMG-20140613-00109.jpg (147.76 KiB) Viewed 15724 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
the window frame roughed in.
- IMG-20140613-00110.jpg (281.41 KiB) Viewed 15724 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
after blasting the cab, replacing both floors and seam sealing all the joints. still needing to replace the steps
- IMG-20140818-00128.jpg (267.69 KiB) Viewed 15723 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
separating the cab from the frame.
- IMG-20140801-00120.jpg (276.94 KiB) Viewed 15722 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
cab is blasted
- IMG-20140818-00129.jpg (239.95 KiB) Viewed 15721 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
frame is blasted and is getting sealer
- IMG-20140809-00123.jpg (241.28 KiB) Viewed 15721 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
frame is now painted
- IMG-20140818-00126.jpg (353.07 KiB) Viewed 15721 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
mustang gas tank is not installed after building brackets
- IMG-20140818-00125.jpg (403.94 KiB) Viewed 15721 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
body now has sealer on it and PPG AEU on it's underside. time to go back on the chassis
- IMG-20140823-00132.jpg (232.24 KiB) Viewed 15720 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
I changed my mind on what king of truck it was going to be. wanted something that handled and drove like a newer truck. bought the industrial chassis dakota kit. it's very nice and well engineered.
- IMG-20151121-00438.jpg (254.65 KiB) Viewed 15720 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
found a complete 87 Dakota at the local wrecking yard
- IMG-20151121-00439.jpg (281.81 KiB) Viewed 15720 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
I upgraded to the Dodge D150 rotors and will be using the Willwood calipers
- IMG-20151122-00441.jpg (269.4 KiB) Viewed 15719 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
installed the rack and pinion and new rotors. finally have a rolling chassis again.
- IMG-20151125-00443.jpg (346.12 KiB) Viewed 15719 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
here as it sits currently. have lots of metal and body work to go.
- IMG-20151125-00442.jpg (228.53 KiB) Viewed 15719 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
Wife decided on colors. PPG Salsa Red and Kasmir. Fenders, lower valance, core support and inner fenders are bodyworked and painted.
- IMG-20140508-00077.jpg (104.76 KiB) Viewed 15719 times
1965 F-100
1962 F-100 Unibody
1962 F-100 Unibody
