1964 Shortbed "Rust-O-Mod" Build
- surfcanada
May 2015 - Got a rockin' deal on a 1964 F100 that was an abandoned project started by a guy who lost interest in finishing. The truck came with a recently rebuilt 302, a C4 tranny and partially mocked up Crown Vic front end. Small amount of rust in the floor, but less than what I've seen before. The plan now is to get it street worthy and take it to a fab shop to install the engine, mount the front end and get the brakes working. Probably a year long project - we'll see - here we go!
- trailer1.jpg (1.23 MiB) Viewed 23240 times
- surfcanada
Re: 1964 Shortbed "Rust-O-Mod" Build
You gotta love the surface rust on this truck. Nothing damaging - Just right!
- trailer2.jpg (1.27 MiB) Viewed 23238 times
- surfcanada
August 2015 - Finally made it to my appointment at the fab shop - Needfulthingz in Lancaster, CA. The Crown Vic front end was already mocked up but still needed some adjustments and welding needed to be done.
- dropoff1.jpg (1.15 MiB) Viewed 23236 times
- surfcanada
302 in the back of the pickup - Needs to be in the front!!!
- dropoff2.jpg (1.15 MiB) Viewed 23235 times
- surfcanada
Empty engine bay. Notice the white trans mount - it was made out of an old floor jack handle.
- dropoff3.jpg (1.19 MiB) Viewed 23234 times
- surfcanada
September 2015 - Front end installed. Rear brackets welded in.
- CroVic3.jpg (995.69 KiB) Viewed 23233 times
- surfcanada
Spacers welded in for front suspension - Awesome welds!!! Angle iron added to strength under the brackets.
- CroVic2.jpg (874.28 KiB) Viewed 23233 times
- surfcanada
One more view of Crown Vic front end
- CroVic1.jpg (952.3 KiB) Viewed 23232 times
- surfcanada
October 2015 - Front springs cut
- FrontSpringCut.JPG (1.12 MiB) Viewed 23213 times
- surfcanada
November 2015 - 302 installed, new front core, new radiator, new power brakes, new exhaust, fenders back on.
- engine2.jpg (950.82 KiB) Viewed 23231 times
- surfcanada
Electric Fans
- engine1.jpg (1.02 MiB) Viewed 23230 times
- surfcanada
December 2015 - Got the stance right. Cut the front fenders for turning room. Added @ 2.5 inches of space.
- Street1.jpg (1.08 MiB) Viewed 23229 times
- surfcanada
Got the rims and tires mounted - 245/35-20”. Running the stock 9” right now with 2” wheel spacers to match lug nuts on the Crown Vic front end. Eventually, I’ll install 8.8 rear axle.
- street2.jpg (1.03 MiB) Viewed 23229 times
- surfcanada
Side View
- street3.jpg (1.02 MiB) Viewed 23229 times
- surfcanada
Welding up the openings at my friend’s motorcycle shop.
- fender1.jpg (915.75 KiB) Viewed 23229 times
- surfcanada
Side view
- fender3.jpg (852.11 KiB) Viewed 23229 times
- surfcanada
Top view
- fender2.jpg (918.81 KiB) Viewed 23229 times
- surfcanada
Welding pieces in
- fender4.jpg (890.76 KiB) Viewed 23229 times
- surfcanada
Welding done
- fender5.jpg (945.35 KiB) Viewed 23229 times
- surfcanada
Front view of weld
- fender6.jpg (929.53 KiB) Viewed 23229 times
