todays score
ezernut9mm
Sweden
todays score
Post by ezernut9mm »
got me a full set of k/h ford 16" "innie" wheels.
the pie crusts look pretty good for being 40 plus years old, but i'm not gonna run em.
Re: todays score
Where in the world did you snag them?
ThinLizzy13
Re: todays score
Post by ThinLizzy13 »
shipwrecked wrote:Where in the world did you snag them?
X2 I'd like to take some notes on your methods lol
robertrpeak
Re: todays score
Post by robertrpeak »
Why do they call them "innies"?????
Robert
36truck
Re: todays score
Post by 36truck »
If you look close at the second picture you can see the hub cap mounting nib is on the inside of the dish. Not on the outside like later wheels.
Tom Williams
born4ford
Re: todays score
Post by born4ford »
Geeze, what a score. I got 2 of mine in a town about an hour away, 1 from North Carolina, 1 from Tom and a nice guy on Craigslist shipped me one from Wisconsin. It only took 6 months to round all 5 up.
Julie
Johnny Canuck
Re: todays score
Post by Johnny Canuck »
is yours a one ton Ezer?
Re: todays score
f250 wheels
they sure do look a lot nicer than the one you sent me with the spider, although i have cleaned that one up pretty good and almost ready to paint
wish i would have brought all the ones i had when i moved down here
Johnny Canuck
Re: todays score
8 lugs for a 3/4 ton. Man they overdid things then eh? shrug.gif
Re: todays score
they used 8 on the f250s at least into the mid 1990s, i have no clue as to what is on them since then as i have not owned or worked on anything any newer.
ezernut9mm
Sweden
Re: todays score
i am just wanting my 250 to have that desired f100 appearance. some 225/70-16s and innie caps and it should kinda take to that look. lol
as for finding this stuff, let's just say i spend a lot of time on craigslist. a lot of time. the best scores seem to be when someone makes a typo and their stuff doesn't show up in the normal searches. lol.
Re: todays score
ICEMAN6166 wrote:they used 8 on the f250s at least into the mid 1990s, i have no clue as to what is on them since then as i have not owned or worked on anything any newer.
Still eight lug; like every other major manufacturer, they had to "metrify" the pattern and offsets so the late stuff won't interchange. Still not sure what Ford was thinking on the six lug one tons, however????
That and the crappy later SEVEN lug trucks; Ford couldn't even decide if they were "heavy duty F150's or "Light Duty" F250's!
End of rant!
Re: todays score
Toyz wrote:Still not sure what Ford was thinking on the six lug one tons,
not a math guru but guessing 6 9\16" lugs likely hold more weight\strength than 8 1\2" lugs and can obviously be torqued more
Re: todays score
Not sure where the point of equality is; but normally, more slightly smaller fasteners result in more clamping force with less torque. This could certainly become a factor on the side of the road with limited tools available.
Industrial compressor rods offer a good example; the rods were originally secured with one very large "jam" nut requiring a very large tool, and preferably a very large mechanic, to bring to the required torque. The advent of Supernuts changed that! A 3 inch or larger Supernut is ran up by hand, then secured by an abundance of fractional sized cap screws which result in superior clamping with much lower torque and effort.
