Installed my COM back in 2001,rebuilt then..decided to get it back on the road last Sunday....but I don't remember if I filled the torque converter...I was told not to start it dry...True or False.....I ask this question on FB,one guy said add about eight qts.then top it off when running,don't know if he's a member here or not....need some more input from real Slickster's
Torque Converter Question.....
Re: Torque Converter Question.....
You know to use type F transmission fluid in the C/M. I just checked the Ford manual for our trucks and it only said the transmission held a little over 10 quarts. I cannot say that for sure, as I really did not understand what transmission the spec was for. As to the question about filling the converter, it can't hurt to put some in it. At least I've never heard of someone blowing up a tranny that way.
If you don't get the answer your looking for here, try this;
http://www.network54.com/Forum/260730
longcabjohn
Since it is together, pull coil wire and crank and it will turn pump and put fluid into converter. When first starting I would jack up rear and put in drive. Be sure to use brake before
putting into park.
Johnny
putting into park.
Johnny
I did some reading and the book says to put in 5 quarts and then start the motor and bring it to 1200 rpm until warm , then let idle and check fluid with the engine running then ad if needed . it also said to run it thru the gears before checking. Said nothing about filling converter.
bruceandersson
I would have the back end up on jack stands to avoid as much resistance as reasonable. I'd then pull the plugs and crank to allow the pump to circulate what it can. Then start on the stands and run through the gears, checking fluid as necessary.
OK,looks like I can proceed.....fill 1st.crank it over w/ no spark then start......Thanks for the replys .....
