So my dad's been building his truck for years to go and do this and he finally got it done... just in time for the USFRA (Utah Salt Flats Racing Association) "World of Speed" a couple weeks ago. He took his truck down and spent about 4 days down there. He passed the tech inspection, which was what he was most nervous about, with flying colors.
His truck is a '61 Ford "Unibody" (no seperate bed/cab) with a built 292cid Ford "Y-Block" OHV V8. He's running in the "Production Pickup, 300cid and under" class... which basically means a motor that came in the truck from the factory, and a mostly factory body/frame (no fiberglass panels, etc). It's built specifically for the flats... full interior cage, full interior and engine fire supression system, all the safety goodies like a 5pt harness, window net, etc for the driver.
The motor is punched out to JUST under 300cid (about 299), is running 10:1 compression with some head work and a nasty cam, custom-built headers... but the best part is that it has a Hilborn mechanical "air bleed" fuel injection system which is totally period perfect and really trick.
This was his first time out on the salt, and he ran a personal best of 102mph, which was pretty good for a first time. The record is somewhere in the neighborhood of 150 I believe. He's already planning to go back, but with some changes to the truck. 1st, instead of 3.0 gears, he's going with 3.5's... 2nd he's going to swap in a closer ratio 4-speed transmission instead of the stock 3-speed because he had trouble getting the motor back up to peak after the 2 to 3 shift due to the gears... Oh yeah, and he's tearing the motor down to put in higher comp pistons, lighter rods, and he mentioned some more work with the heads.
Check out the pics! (EDIT, if I could post pics on here you could see them. Very cool-sorry!)
I wish I could've taken time off work to go... I will next time though.
Also, http://www.halfpastnoon.net/videos/PICT0004.MOV
(Need quicktime for that one... right click, save as-takes forever, even with DSL to down load
If I
