Just a few 64 F100 questions
64kust
Post by 64kust »
Hello everyone i just joined the forum,,,,i have a 64 F-100 custom cab with a 302 in it and was wondering what headers would yall use??? and also i gotta ask about dropping it,,,would putting the axles on the springs work on a 64???,,ive seen a 60 with it done and was wondering if its the same on a 64
66fordtrucknut
Post by 66fordtrucknut »
Welcome to the club from Md. Can't help you much, I have the original 223 and run stock hieght, some one will for sure answer your question.
Charlie
62' SWB uni 223
66' F-100 Short/wide 352
78' F-350 dually dumpbed 400
12' F-150 5.0 3:73 LS
Choppermike
Post by Choppermike »
Welcome, I have 70 model truck headers on the 302 in my 62 and they work fine. Dropping the axle is better than a flip. I opted for an IFS setup.
Mike
1962 F100 Unibody- Ol' Jack
65 Mustang Coupe
92 Mustang LX
2006 Mustang
[albumimg]3443[/albumimg]
FORDMANLCRACKEL
Post by FORDMANLCRACKEL »
:welcome:
lONNIE
Johnny Canuck
Post by Johnny Canuck »
I have a 64 with a 302, used Mustang shorty headers. Looks like they will work just fine, but I have never had exhaust pipes hooked up to them yet.
JC
f100matt
Post by f100matt »
:welcome:
-1966 Ford F100, 352, 4 speed, smoke grey, mustang buckets
-2003 Ford Ranger XL, 3.0, 5 speed
-1989 Ford F250, 460, highboy, 4x4
ezernut9mm
Sweden
Post by ezernut9mm »
my 64 had a 302 with hedmann long tubes on it, but since the po did it i don't know the part #. sorry.
shawns fords
Post by shawns fords »
Welcome. I run a 460 in my 64 it has sandersons on it, they are shorties, but you can get a set from them for a 302 or any other engine. can also special order custom built to your measurements from them.
this is the good side
:welcome:
oldtrucks
Post by oldtrucks »
64kust
Just about any header you want to use will work. Shortys will work the best but long tube will present some interferance problems with the motor mounts and cross members.
:welcome: The water here is fine and ask a lot of questions so the rest of us can feel usefull.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1962 UNI Short Box, Stock Y block, 4 speed Image
1972 F 250 4X4 429 4 speed Dana 70 rear
1977 F 350 Camper Special, Ranger, Super Cab
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
64kust
Post by 64kust »
Thank you all for the advice,yeah i got to looking inside the engine bay and shorties look like the best way to go so they dont run into anything,,,,any suggestions on how to lower the front??
shawns fords
I could recomend a few things to do. I like my front end up a little, kinda like an old gasser car :lol: . you could reverse your eyelets on your leafs. I did remove my center leaf and reassembled them. it dropped it down just a tad but not very much also changed the wear location on the old leafs. I think the best way would be to buy a front axel thats already made to drop. or look for some drop spindles ( if there is such a thing for these trucks)
ezernut9mm
Sweden
no. no drop spindles for these trucks. reversed eye or mono leaf springs, or sub frame it.
The Big M
Post by The Big M »
Technically, what works for a '60 will work for a '64. I've seen examples of 61-64's with the front axle over the springs, but I can't really say I'm a fan. I believe it's been discussed here before, so you may want to do a search.
Oh yeah, welcome!
You can get a little lower by removing some leafs, I pulled 3 from the front of my Uni. Everything up front on my truck is real tight though, I don't think I'd try it if your's needs king pins, tie rod ends, etc. Be sure to remove every other leaf NOT ones next to each other.
I haven't done the rears yet, I'll do them after I get the new tires & wheels because I'll run taller tires on the back and want to keep a little rake in it. Some will say this worsens the bump steer but I haven't noticed any issues with it. Here are some pics.
[albumimg]2815[/albumimg]
[albumimg]2814[/albumimg]
[albumimg]2813[/albumimg]
