Alternator?
Alternator?
Okay, the wife's 2000 taurus has the battery light coming on with engine running. I figure it's the alternator. I take the car to the local O'Reilly's just to let them "check" it. They hook up their gizmo to the battery and I start up the car. Guy tells me that, "Yeah, it's putting out 14 volts, alternator is fine", WITH THE BATTERY LIGHT ON, he is getting 14 volts at the battery. Hmmmm... I take it home. I notice that when I rev it up to about 2 grand, the light goes out. When it is idling, the light comes on. I still think it is the alternator. What do y'all think?
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
Well, I yank the battery out of the car and take it down to see how THAT tests out. Tests out fine. But NOW when I start the engine, the light is on permanently, won't go off no matter what I rev it to...(sigh)...oldtrucks wrote:GLindley
Just went through the same problem with our 96 Taurus and it was the battery. Wouldn't keep a charge. New battery should fix it right up.
Gene
blackagatha
Took it to a reputable automotive electric garage this AM and found out that the alternator was crapping out after it was running for a while. Replaced it with a heavy duty one, so the wife is good to go!
Gene
shawns fords
Gene, that light is run through the alternator, what was happening is the guy at the parts store only saw how many volts it was giving, he never checked your AMPS, the reason the alternator was turning on the light at low RPMs then going off at hight is the Alt. couldnt generate enough AMPS at lower RPMs
I have seen many show plenty of volts but not enough amps. I learned the hard way, always check everything glad you got it fixed, I hope the mechanic was Gentle
this is the good side
