Alternator?
GLindley
Alternator?
Post by GLindley »
Okay, the wife's 2000 taurus has the battery light coming on with engine running. I figure it's the alternator. I take the car to the local O'Reilly's just to let them "check" it. They hook up their gizmo to the battery and I start up the car. Guy tells me that, "Yeah, it's putting out 14 volts, alternator is fine", WITH THE BATTERY LIGHT ON, he is getting 14 volts at the battery. Hmmmm... I take it home. I notice that when I rev it up to about 2 grand, the light goes out. When it is idling, the light comes on. I still think it is the alternator. What do y'all think?
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
just because the alt is putting out 14v does not mean the battery is taking it.
swap out a known good battery and see if the light goes out.
GLindley
Post by GLindley »
I guess I wasn't aware that the on board computers can detect if a battery is taking a charge or not?!
Gene
that i do not know.
pretty sure to say its not safe to pull the + cable off when its running like a slick to test the alt because of the puter.
oldtrucks
Post by oldtrucks »
GLindley
Just went through the same problem with our 96 Taurus and it was the battery. Wouldn't keep a charge. New battery should fix it right up.
Mike Kincheloe
Mikes Old Trucks
I restore old trucks and cars
1950 F7 Cab and Chassis
1976 F150 4 Speed 4 X 4
1996 Taurus
GLindley
Post by GLindley »
oldtrucks wrote:GLindley
Well, I yank the battery out of the car and take it down to see how THAT tests out. Tests out fine. But NOW when I start the engine, the light is on permanently, won't go off no matter what I rev it to...(sigh)...
Gene
blackagatha
Post by blackagatha »
could just be your POS computer shorting out...
oldtrucks
Post by oldtrucks »
Guess it is time to have the codes read. Do you know how to do a self test on the computer??? Otherwise take it to a shop and have them pull the codes. Has the check engine light come on yet??
Mike Kincheloe
Mikes Old Trucks
1996 Taurus
GLindley
Post by GLindley »
Took it to a reputable automotive electric garage this AM and found out that the alternator was crapping out after it was running for a while. Replaced it with a heavy duty one, so the wife is good to go!
Gene
shawns fords
Post by shawns fords »
Gene, that light is run through the alternator, what was happening is the guy at the parts store only saw how many volts it was giving, he never checked your AMPS, the reason the alternator was turning on the light at low RPMs then going off at hight is the Alt. couldnt generate enough AMPS at lower RPMs
I have seen many show plenty of volts but not enough amps. I learned the hard way, always check everything glad you got it fixed, I hope the mechanic was Gentle :lol:
this is the good side
