new ignition/distributor
don luster
Post by don luster »
I have the loadmatic vacuum distributor in my 63 223 six cylinder engine. What do you 6 cyl guys run stock, modified, or later model modified etc. tell me the good points and bad Thanks for you answers. Don
Don, I would say just one word - Pertronix.
fmartin_gila
Post by fmartin_gila »
Pertronix it is. I kept the Holly 1904 with the pretty glass bowl and the stock dizzy with a Pertronix I and the matching coil. Has worked very good over the years. I do carry a point set & condenser along with a spare coil, but have not had to use them.
Fred
cdherman
Post by cdherman »
If you still have the loadomatic carb (has spark control valve) you must keep the loadomatic dizzy. In that case, I'd go Pertronix too. Ignoitor II has variable dwell and more importantly, it won't burn up if you leave the ignition switch on.
If you do NOT have a loadomatic carb, then now is the time for a DS-II or later dual advance dizzy setup.
1683
Planned/considered upgrades:
bobenhotep
Post by bobenhotep »
I run a stock load o matic dizzy with points hooked to an MSD 5 box. If you keep the points find a way to amplify them so they last a long time. The carb is a Holley 94 2bbl with spark valve. I thought it was a Stromberg when I first saw it and grabbed it, then noticed the spark control valve and wheels started turning. I found it half a mile from my house in the dump and figured Id get struck by lightning if I did not use it...
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Truckfarmer2
Post by Truckfarmer2 »
I thought someone on this site said that the Duraspark ignition system from a 300 can be retrofitted to a 223/262.
I am sold on the Duraspark II system.
If you continue to buy imports, where will your children work?
don luster
How do I tell if I have the correct carb with the vacuum for the distr. If someone can direct me toward a learning spot that will tell me how to redo a later distr. because my brotherinlaw has a maching shop and he will do me a favor with any machining etc. Thanks for you help so far
don luster
Thanks for your replies. I went to my manual and found out what the spark advance looks like. Now the big question is how do I check this out to see if it working properly. Can this be checked out with a timing light and see if it meets the adv on the distr by looking at the harmonic balancer. Can vacuum be applied to the spark adv and see if it hold vacuum. Should the distributor be disassembled and make sure the plates etc move properly and relubed etc. Thanks again Don
cdherman
Post by cdherman »
All good questions. Certainly, a loadomatic dizzy/carb setup should have advance with higher RPM. A timing light should verify this. Keep in mind, high RPM in neutral will have much higher manifold vacuum than when the engine is underload. So what you see in your driveway may not reflect the actual advance curve of the engine. But it should give you an idea.
I have no idea how to ckeck and advance canister -- if you suck on it and you get free flow air, I do know that that is a problem! Some dizzies are adjustable, I've not monkied with a loadomatic dizzy so I don't know.
As for dissassembly, yeah, I took my remaned one apart to just understand how it worked and relubed it upon reassembly. But if you are getting decent advance, there is something to be said about not screwing with things that don't work.....
I've never figured out the proper way to squirt lube into the little flapper port that lubes the top part of the shaft of the dizzy, just in case you were wondering....
1683
blackagatha
Post by blackagatha »
whats the deal with the spark valve and loadomatic????? Seems like a carb is a carb and a dizzy is a dizzy!!!! NO?????!!!!! strange.
re54drider
Post by re54drider »
Go here for information on the loadomatic:
http://fordsix.com/forum/viewtopic.php?t=18841
don luster
I could not get yourpage to load about the distr. But what i remember is that there are two ports inside the carb. one is in idle port and second one is above the ventures and they vary the amount of vacuum to the distributor and it overcomes the spring pressure of the part that controls the advance to the plates of the distributor. please repost the address of the page, i would like to look at it. Thanks
re54drider
Try copying the link into your browser address bar if the link is not working. I am using IE so if you are not maybe that is the issue.
R Pope
Post by R Pope »
The Six in my '66 Slick (240? 300?) had a loadamatic and ran like crap. I put a dist. out of an '82 300 with Duraspark stuff and it's a different truck all around. Starts instantly, smooth as glass, and better mileage. Even quieter out the tailpipe.
