What kind of gas mileage do you get?
- ripsnorter
What kind of milage do you get?
And with what combo engine/tranny/rear end/cruise speed/rpm?
Just curious what different setups and mileage you folks are using/getting.
I figure with my 223 6 (original, never rebuilt i dont think) and the 3 on the tree I'm getting 15MPG. however the rearend is probably high 3s at least, with cruising being around 55. 60 if i push it. No tach though so not sure of the RPMs. gotta be hitting 3000 or so though at 60. Hence why i dont do more than about 55.
by the way, anyone know how to figure out the codes on the rearend to get the ratio? would the VIN tell you that perhaps?
My 390 shortbed gets about 12 to 14 with the 2.75 gears I installed. Depends on how much my foot weighs that day.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
- ripsnorter
12-13 if i keep my foot out of it. the rear end code is the one under axle
on the tag
http://home.earthlink.net/~threynolds2/ ... s6166.html
on the tag
- ripsnorter
My 73 with the 300 and 3-speed with 3:1 gears gets 17-18mpg, and I drive it fast up to 80mph.
The 300 is 60 over with a stock cam/offy intake/hooker headers/ Holley 600cfm carb.
I was running 15mpg them I redid the wheel bearings all the way around and aired the tire up right. That made a huge differance!
ras4434
- Johnny Canuck
- FORDMANLCRACKEL
66 swb/4x4/351w 4v/np435/3.55 gears/35x14.50 about 12 mpg.
Lonnie
Lonnie
- DanSanDiego2000
1965 F100
L6 240, single barrel carb, 3.00:1 rear, the tallest tires I could possibly fit and afford (29"), and loaded, unloaded, freeway miles and city miles..... typically 14-15 mpg, with rare stints of 18 mpg.
However, looking forward to my conversion to Clifford 2bbl water heated intake, tri-Y ceramic headers, and Demon 2bbl carb. Supposed to be a 45% increase in torque and horsepower, and an increase in MPG. I'll let you know as soon as it's done. Should be Fun.
- needmoretime
- 66fordtrucknut
