Garbz Maniacial in the closet Building of a 63 Ford truck
Garbz
See i cant get away from it...
Will drop in pics and tech as i can from my Photo bucket and archives...
Garbz
Garbz
Garbz
Grill Mods
Modified the grill to delete the turn signals. I will use Lucas type headlights with built in TS.
<a href="http://s368.photobucket.com/albums/oo12 ... 200074.jpg" target="_blank"><img src="http://i368.photobucket.com/albums/oo12 ... 200074.jpg" border="0" alt="New Grille As modified" ></a>
<a href="http://s368.photobucket.com/albums/oo12 ... 200071.jpg" target="_blank"><img src="http://i368.photobucket.com/albums/oo12 ... 200071.jpg" border="0" alt="New custom Grille" ></a>
Garbz
Garbz
Garbz
Grill Mods
Just one of the many things happening
Garbz
Garbz
- ezernut9mm
great build garbz. can't wait to see the finished product. it will 180* out of what i'm doing for sure. i hope to bring my whole project in for less than 1500 and minimal labor. lol. yeah, right.
Garbz
- ezernut9mm
ok. we are on par $ wise, but we are definately 180 out in the skills department. lol.
Anthony
blackagatha
- Roger Carter
Garbz
- ezernut9mm
- Alan Mclennan
Garbz
- Alan Mclennan
I noticed we both have rubber mallets in our pic`s, If in doubt give it a clout, the bigger the doubt the bigger the clout!
Garbz
Yep if it don't fit force it. That is my Motto Alan..
Dave the shaft in the column is a cut off from a 61 to 64 ford box with a double D machined on the end. The collar to hold the column together is a piece of .125 3/4" ID tubing with 2 tabs welded to it with a cross bolt. Holds everything together nice and will allow me to run a stock 17" slick steering wheel.
The lower is a Flaming River Double D S/S that is a slide in fairly tight fit to the stock double D vibration joint at the bottom. It is in there about three inches. allows a bit of slip as the body and frame flex.
Garbz
Garbz
Garbz
Johnny I am shooting to have it there.
Yes i placed a 2" Z notch in the front frame to slam it down lower.
I may be just as you see it in all patina and rust. I want to assemble everything get it going then blow it apart for powder and paint.
I figure i can do that in the next four months. Just need to watch the budget.
Garbz
Garbz
- twistedfreak
Garbz, the truck looks great! I will have to pick your brain here on the Dodge Dakota front end. I am going to ditch my entire Dropped I Beams, front disk brakes, etc and go with this with the fullsize hubs, etc to run 5x5.5. Only thing I need to figure out is the brake booster, steering, etc. With that steering setup like that, will my 351W fit with my 5.0 foxbody mustang headers? It took me a long time to find headers that fit in my truck and I have to backorder them which took forever and finally got something that looked great, functioned nicely and fit, I'd hate to go through the same thing again if they will not fit...
What did you weld the front end up with and where did you get the parts to rebuilt the ball joints, tie rods, bushings, etc?
Thanks for any info at all on this and tips!
