ID this tranny... "I think" I found one
norville
Post by norville »
I do stop in every now and then. I'm not completely out of the ford game. I didn't mind the 2pc shaft. It made getting it adapted easier. I only had to take a 2ft piece to the shop. I had to have him cut me a longer shaft, he reversed my carrier bearing and installed a new u-joint for $125
here's something I picked up for next summer.
I just spotted a TOD I may throw it in the bronco. I have to comment, the ZF trans are getting real cheap, especially 2wd ones, you may want to keep an eye out for one. Or even a ranger/mazda unit if your not gunna be beating it.
bob
norville wrote:I do stop in every now and then. I'm not completely out of the ford game. I didn't mind the 2pc shaft. It made getting it adapted easier. I only had to take a 2ft piece to the shop. I had to have him cut me a longer shaft, he reversed my carrier bearing and installed a new u-joint for $125
bob
nice Bronco.
i cant find a decent uncut early bronco or i would own it.
dont want one jacked up with the wheelwells hacked out.
jwh f-100
Post by jwh f-100 »
Coll rig, we had a old bronco hunting rig years ago, what a beast..
I was down in wilkes-barre tonight for a hockey game and then hit the River Street Jazz Cafe for a couple beers. Not a bad little joint and the band was great..
Jason
Beer will change the world.
I don't know how but it will.
norville
Post by norville »
my folks have season tickets.
bob
jwh f-100
Post by jwh f-100 »
Anyone know what is involved when removing the shifter? Any special tools?
I hope this week-end I can start removing this tranny.. Thanks!
Jason
norville
Post by norville »
I think I just pulled the shifter off the stub. there was a little plastic piece holding there??? My unit was already moved.
bob
R Pope
Post by R Pope »
An interesting piece of knowledge, Jeep used that trans and built a top shifter that replaces the tin cover. You chuck all the stock shift mechanism and end up with a shifter farther forward, but Third and Fourth are in the wrong positions, Fourth is toward the dash.
The top will fit an SROD too. You have to tear them down to get the stock shift mechanism out first.
jwh f-100
Post by jwh f-100 »
That is interesting... If this TOD does'nt hold up maybe I could use the shifter on a top loader, SROD, or a SMOD..
Here is some info I though was interesting... Click on thumbnail to view..
Jason
jwh f-100
Post by jwh f-100 »
Roger Carter wrote:For what it's worth...
I have an all cast iron 3+1 in my '66. It is behind a warmed over 390 and has been there for ten years with no problems or issues. The 3+1 was a nuts and bolts swap, other than shortening the driveshaft, for the 3 speed that was in the truck originally. My 3+1 looks like the Orion trans that Hawkrod posted.
As I remember, the 3+1 was from a '77-'78 Granada or Monarch that had a 302 for power. I believe the all cast iron units were available in F-100's and Econolines in the late '70's also.
As previous posts stated the SROD and the aluminum cased 3+1's are very weak transmissions. Trust me on this.
Hope this helps.
Roger Carter
Roger, Do you have a bench seat?? Just wondering about shifter location with the SMOD.. It looks like it may be a tight fit.
Anyone know what is avalible for aftermarket shifters?
Jason
norville
Post by norville »
Jason, a guy local to me has a TOD with bell and shifter for sale for $175.
I think you should be able to get one of those horseshoe or "C" shifters and make it work
bob
BMorrison
trans
Post by BMorrison »
IF it is the srod they are not bullet proof but no trans is .
I have a mustang one in my truck workes great .
cant belive the fuel mileage better truck than before .
If its cheep I would do it agin i still have an extra for the next slick .
jwh f-100
Post by jwh f-100 »
norville wrote:Jason, a guy local to me has a TOD with bell and shifter for sale for $175.
bob
Thanks Bob. I also found a SMOD, the iron cased side mounted shifter. I may go look this weekend but I will keep that in mind.
If your looking for something for your bronco I know where there is two ZF trannys. One is 2wd and one is 4wd.. Both for small block.
Jason
norville
Post by norville »
shoot me a PM on those tranny's price ect..
Personally I think the TOD is a better tranny. I do not know if the the smod had better spacing on the gears or not?
bob
itsmywifestruck
Post by itsmywifestruck »
I have 2 of those TOD tranny's...I think. I have wondered about the durability of them. They came factory behind 300's...and I know people who just flog those trucks, and no prob...so it must be decent. I just wish it would fit behind my 223.
ROb
Buzzin Half Dozen
jwh f-100
Post by jwh f-100 »
itsmywifestruck wrote:I have 2 of those TOD tranny's...I think. I have wondered about the durability of them. They came factory behind 300's...and I know people who just flog those trucks, and no prob...so it must be decent. I just wish it would fit behind my 223.
ROb
Rob, matt2491 has one behind a 292. I think 292 and 223 bells are different but don't they use the same trannys? One of the guys with more brains than I may be able to comment/help.
Jason
Casey 65
Post by Casey 65 »
Jason, Thanks for posting the thumbnails. I've been looking for a site with this info. you da man! :rocker:
223s & 292s - 4 bellhousings. The 6 & 8 each have a different bell on the engine end. 3 & 4 speed bells are different also. To the best of my knowledge all 3 speeds and all 4 speeds are the same.
Greg D wrote:223s & 292s - 4 bellhousings. The 6 & 8 each have a different bell on the engine end. 3 & 4 speed bells are different also. To the best of my knowledge all 3 speeds and all 4 speeds are the same.
Thanks Greg, i did not know that, now i will have to go see what is what.
thought only the 6/8 were different bells.
DCarr
Post by DCarr »
Jason, on the shifter-it's real easy to modify for the bench seat. I had to do it for my Richmond shifter.
Just z'd it the required distance. I'll post a pic if you need one.
jwh f-100
Post by jwh f-100 »
Interesting..
So if we knew what bell Matt has on his 292 ( a 3 speed or a 4 speed) there may be an answer to Rob's question. It would answer the bell question anyway, I guess it is possible other changes were made, pilot bearing, clutch, pressure plate... :dontknow: If nothing else when I do the swap I do some measuring for comparison...
David, I'm thinking I'll be ok after seeing stronger66ratfink's toploader pics... thanks.
Jason
