Ford Aerostar IFS install in F100
Cool, now I'll have to bring a bigger wagon to the u-pull-it.
Thanx, Tim
Thanx, Tim
My chrome steelies are drilled for two applications BUT I am having a huge brain cramp.. They are either drilled for Ford car & truck OR ford & chevy truck.
Just a possible option... I could measure if anyone is interested in the same style...
Jason
Beer will change the world.
I don't know how but it will.
itsmywifestruck
So you used the same length axles on both sides? The rear end in my truck does not have same length axles. I never noticed it till we pulled the bed, but it definitely sits off to the side. If I can get my hands on some plain steel wheels for my hubcaps, I am not gonna worry about the rear end yet. But I did have a guy stop buy and wants to buy that rear end...so if the price is good enough, I may have to let it go.
ROb
ROb
Buzzin Half Dozen
itsmywifestruck
If you get a chance to take a look at that before I do (I'll reply when I do), can you post up some info on that for everyone?deviant1 wrote:Thanks IMWT, I might look into this a little harder. I might go to the Pull-a-Part and stare at the Aerostar frontend in person and take measurements.
I'm interested in this type of setup also.
Thanks!
63BIGWINDOW
Truckfarmer is correct,done a few bumpsides over the years with them and work perfect,definately use truck bearings(learned the hard way),it's getting very hard to find these cars now,you can also use late model 8.8 rear discs,newer explorers etc,almost a 100% bolt on,those are hard to find now,people buying them up for e-bay selling them for fox mustangs,older car swaps.I usually pay $40-50 a set complete,guys put them on fleebay for $250-up,just a thought.Truckfarmer2 wrote:we grabbed the backing plates but did not have to use them on the truck we converted. Just used 2 left axles and the drums.
The only problem we had was that the car's bearing retainer was wider than the truck's and would rub on the axle seal. Installed a truck bearing keeper and all was good.
Be sure and measure the backing plates if you do the disc swap the backing plate bolt holes measure 3.5x2,which is the same on the big bearing 9".
63 big window shop truck
93 2wd lightning/bronco-wifes driver
itsmywifestruck
So for an update....I got the 223 set back in the truck. I had about 1/2" clearance between the pan and crossmember. I have to modify the rack mounting to point the rack at the cab...but yeah, i had to remove it, because it definitely didn't clear. I am gonna get tires on the front that hold air, and slap the front sheetmetal back on next week. I will get some updated pics when I get that done. Oh, and my neighbor is sposed to be fabbing up, and possibly installing my sway bar mounts this weekend, so we will see how that works out too.
ROb
ROb
Buzzin Half Dozen
- Gary Seymour
itsmywifestruck
Truckfarmer2
itsmywifestruck
Yeah, they have a pretty neat, very tall floor shifter. And the big plus, I think they linkage/cable would prolly hook right up to a Ford AOD. I snagged one, but I don't think I am gonna use it. Those trucks also have a very slick accelorator pedal/cable that i simple and easy to remove/adapt from how it looked to me.
ROb
ROb
Buzzin Half Dozen
itsmywifestruck
The centerline is very easy to find on the frame. THe truck uses bumpstops nie and centered above front axle. Those holes make a very nie point to center from.
And on another note...I am gonna have to pull the 223 out. It clears the crossmember, but I am having some wacky issues with it clearing the steering rack, which sticks up maybe almost an inch above the crossmember. So, it is back to the drawing board for the powertrain. I have just happened upon a Explorer 302 with GT40 heads...so I am scratching my head.
ROb
ROb
Buzzin Half Dozen
That Explorer 5.0 would make a real nice choice for a Slick.
itsmywifestruck
I really don't want to run a 302. That 223 is just so good on fuel. But if it don't fit, it don't fit. And you are right, that Explorer motor would be lots of fun. THe explorer also has a 3.73 posi disc brake rear end under it, which would be very nice also. I gotta drag a battery out and see if the Exploder will run before I get crazy yanking the motor. I have a 4 spd tranny with o/d I could run behind the 302 if I can scare up a bellhousing. Oh well. Atleast I got the front end under the truck were I can roll it around now.
Oh yes, made the brackets to mount the steering rack last night and got them mounted. Had to cut the crossmember. I will post up pics sometime this weekend.
ROb
ROb
Buzzin Half Dozen
- in2hotrods
