need some advice
- muskrat2000
need some advice
hey a guy in my town has 73 f150 he is parting out will any of the parts work on my 65 f100
I HAVE A 65 FORD F100 AND A 2000 GT MUSTANG
Anthony
Thunderboy
A 65-66 2WD truck cab-forward will bolt on to frame from 73-79. The bed requires more work because the frame is 4 inches wider and the wheelbase is 4 inches longer than a Slick. It may be a worthwhile swap only if you want frame mounted fuel tank(s), wider rear track. longer wheelbase and updated front suspension. I am doing this on a 66 F250 because I want to use it for towing. Not sure if it is worth it, unless you are good at welding and metal fabrication (I'm not!).Anthony wrote:The whole chassis should fit under a '65 or a '66.... I believe. I am putting my '66 on a '76 highboy and it fit... All the upgrades in one package...
More info available here:http://www.fordification.com/tech/chass ... arison.htm This was written for a 67-72 "bumpside,' so it isn't completely correct for a 65, but you get the idea of what is involved. Happy to assist if you decide to do the swap, and there are others here who've done it.
Drew
66 F250 Frame swap, EFI 408W, ZF 5-speed swap (still!) in progress
63 Falcon Futura EFI 331W, T5, but not much progress... Slicks First!!!
f250 4x4s are different. so are the dually f350s. they did not widen out the frame.
on the 2wd f100/250 if you just mount the bed on the frame there will be a larger gap between the bed and cab and you need to drill new holes in the bed floor.
