The leaf springs on my 65 1/2 ton are wonky. is there a way to fix this without paying LMC $800? Can I take some leafs from my 64 3/4 ton parts truck and replace or add them to my 65? They're about the same width.
yes
the only difference between the f100/250 is the amount of springs in the stack. some might be a bit thicker too but the width is the important part.
I think your best bet is to take them to a spring company and have them rearched. They will also retemper the springs. You will probably have to go to Salt Lake City to find a spring company. Good luck.
Whats the advantage to getting the re-arch vs using leafs from another spring? I've never torn down a stack of springs before, maybe I should just bite the bullet and 'spring' for a new set.
I substitute wonky in place of f'd-up when the kids are around.
I've had springs rearched before and it only last for a while. If they're wompy.. you need new springs. Heck, they're over 45 years old! A local spring shop may be you're best bet. You might also check Kansas City Spring.. For my falcon, it was cheaper to order from them. Their website is generalspringkc.com
