Or maybe the question should be where did my C3AF-AU carb come from because everything I found says the C6AF-L, C6PF-H, and C5AA-A were the carb for the 352 that year.
Also where can I find specs on this carb, I think it is a 4100 series carb but want to be sure of the cfm and what not before I hunt down a rebuild kit to place it on the 302.
What carb came on the 352 in 1966...
killercoating
1966 F100 CC LWB (The soon Air Ride Truck)
1969 Merc. Cougar Eliminator (The Muscle Car)
2003 883 Sportster Chopper (Hand Fabricated)
2004 TOTALED Mitsu Lancer Ralliart (Import Tuner)
NEW TOY - 1936 Dodge Coupe (HotRod)
a 1966 Ford truck with a 352 should have a C6TF-9510-C with an automatic and no thermactor (early ones might have a C5TF-9510-Z), a stick no thermactor should be C6TF-9510-T, automatic with thermactor is a C6TF-9510-S, stick with thermactor is a C6TF-9510-R. The other numbers you have are all car numbers and are not correct for a truck. Hawkrod
