Flasher relay?
Oregoon
Flasher relay?
Post by Oregoon »
Quick but frustrating question: Where does the flasher-relay go, and what does it plug into?
I found mine smashed to pieces bewteen the door and the floor... It seems to have fallen out. Got a new one, and have no idea where to put it. And I have no blinkers, flashers, or brake-lights at the moment--and I am a fan of those! I assume all those circuits run through the relay?
Limestone66
Re: Flasher relay?
Post by Limestone66 »
Like you 'Oregoon', ima learnin too, but i beleive the flasher relay goes into the fuse panel tucked up under the dashboard. Look for the 'L' shaped slots and it plugs into that on the fuse box.
Long live the 352
........Ron..........
1966 Ford F250 Custom Cab {Longbox}
1996 Toyota Camry {Wifes ride}
1940 Harley Davidson knucklehead {Retired in 2006, gave to one of my sons in 2010}
1975 Harley Davidson XLH {Groundpounder}
2005 Harley Davidson Deluxe {Nostalgia} Almost home 'girl'
In memory of Donald G. Roswell- My freind and 'brother'.
Oregoon
Re: Flasher relay?
Post by Oregoon »
No slots on the fuse block (which is mounted on my firewall). All my research says it goes behind the instrument cluster, but I'll be damned if I can figure out where...
Any other suggestions would be welcome!
Re: Flasher relay?
If you are referring to the directional signal flasher, it is located in the under dash harness; two wires with female terminals, one blue wire and one orange w/ a stripe.
Oregoon
Re: Flasher relay?
Post by Oregoon »
Toyz wrote:If you are referring to the directional signal flasher, it is located in the under dash harness; two wires with female terminals, one blue wire and one orange w/ a stripe.
Boom! Found 'em, and plugged in the two-prong unit I got from the parts store. Wasn't sure it mattered which wire went where?
Anyway, now my emergency (four-way) flashers work, but still no brake lights or turn signals... Oh, and my driver-side tail-light appears to be out, if that's a consideration?
Any further suggestions?
Many, many thanks.
Also, I have a long and fiery relationship with wiring. No, seriously: I have set shit on fire with my ineptitude.
tomrooster
Re: Flasher relay?
Post by tomrooster »
There's a little spot where the flasher sits in so it won't fall out or rattle on the support behind the dash just to the right of the steering column. I can post a picture tomorrow night if you need it . Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Re: Flasher relay?
Do all signal lamps light when the 4 way flashers are on? If so, it is not likely to be affected by the burned out taillamp. The exception would be a mis-installed bulb or a poor ground connection. I'll have to consult diagrams on this, but I was thinking a separate flasher was used for turn signals in '66. My '66 wiring manual is not here, so I will attempt to find a good dash wiring diagram.
Oregoon
Re: Flasher relay?
Post by Oregoon »
There are two other female connectors in the same area: One is tied to two wires (red and orange), and the other is connected to a single light-blue/grey wire... Could these be what I need to plug a second relay in to, and if so, any idea what the part number might be?
As always, help is greatly appreciated! Thanks and thanks again.
Re: Flasher relay?
The flasher you purchased should work fine, just switch it over and try it. If that makes the turn signals work, and it should; you can just buy another of the same part number. The only exception would be if you purchased a light duty flasher, if so leave it on the turn signals and specify the same flasher in a heavy duty unit for the four way flashers (more draw).
Finding one smashed flasher kinda threw me; it looks as if you had two separate flasher problems.
Hoofbeat Racer
Re: Flasher relay?
Post by Hoofbeat Racer »
http://slick60s.com/viewtopic.php?f=5&t=11021
This may help you for some wiring concerns
Mark
Oregoon
Re: Flasher relay?
Post by Oregoon »
Hoofbeat Racer wrote:http://slick60s.com/viewtopic.php?f=5&t=11021
Thank you for taking the time to hunt that down and share it. What an excellent resource! I will be printing those before delving into my under-dash spaghetti.
That said, I don't see two separate flashers for turn-signals and four-ways... Am I missing something?
Again, many thanks. I can't begin to tell you how much I appreciate your input.
Re: Flasher relay?
Look at the "accessories" schematic. It should be located to the right of the column and the wire color codes are listed.
F7BIGJOB
Re: Flasher relay?
Post by F7BIGJOB »
Make sure you have power at the brake light switch [ key may have to be on ] having no flasher , you should still have brake lights.
F7BIGJOB
-Steve
1965 F-250 4x4 Flareside
Re: Flasher relay?
Steve is correct; the emergency flashers share a fused power wire with the brake lamp switch.
Oregoon
Re: Flasher relay?
Post by Oregoon »
Great success! I now have flashers and turn-signals. Still no brake-lights, but I think I have the culprit in my sights. Unfortuantely, the skies opened up and I had to go pick up my kids from school, so I'll have to wait to fiddle with the remaining gremlins until Thursday.
