Is This The Correct Alternator Pulley For A 1965 F250?
I read the correct 2 groove alternator pulleys were cast iron. Would this pulley be correct for my 352 F250?
Re: Is This The Correct Alternator Pulley For A 1965 F250?
My pickup was plain dual belt alternator, no other options. Anyone have a photo of the correct pulley?
i got a lot of actual pics, i will keep looking but this exploded diagram does show the 2 belt pulley
only cast iron pulleys i can recall are on the FT that came out of a 65 or 66 bus, not sure if the alt had one or not
looked thru 56 pages of pics and still i have not located the 2 pulley alt , i will look some more.
Thanks. I'll try to relocate that post. Poster said stamped steel pulleys were not correct. Maybe I miss read the truck they were talking about. From what a couple older techs have said on my engine compartment have an old U-Haul rental truck. Apparently the same set up a governed 1 ton would have.
the one in your pic looks like machined steel which is an upgrade over stamped steel
I'll run with that. Wished I kept the round back and pulley that was on it when I first bought it. Never paid attention to what pulley was on it, if still original.
10344 in your post is what a stamped steel would look like if they were going for accuracy.
I found this alternator on a 67 330 MD. The stamping on the pulley is C5TF-10A352-K2. If these trucks had cast pulleys this is probably it. Transferring the pulley to mine till I rebuild the correct round back Autolite on the left.
I didn't see my dual belt application on there.
