65 redhead steering box in a 64 w/ new column
I read so many good things about the redhead steering boxes it makes me want to try one. Problem is my truck is a 64 with the interconnected box and column shift. I'm planning on putting in a t5 or SROD, so the shifter is moving to the floor. I've been looking at flaming river columns and a 65 redhead box. My question is: has anyone put a 65 box in their 64? Using and aftermarket column? What length column did you use and will the 65 box use the same mounting holes? Motor is a 223 without any power steering. I want it to steer tighter with tilt so I can use a smaller 15 or 16 inch mustang steering wheel but I don't need/want power steering. I've read that redhead adds bearings which make the steering much tighter and easier. Also, I don't really want to cut my column. So any accounts of previous experiences would awesome. Thanks so much.
- Roger Carter
Re: 65 redhead steering box in a 64 w/ new column
I have not done the conversion you are talking about and don't believe I have encountered anyone that has. Try using the search function on this site and see what shows up.
The steering systems on the '64 (straight axle) and the '65 (Twin I Beam) are totally different, with no parts interchange. The '64 drag link moves front to rear while the '65 moves side to side. The frames, steering box mounting methods and locations are different between the years as well.
I'm sure what you propose is possible, but not without a considerable amount of work and expense.
Good luck.
Good luck.
Roger Carter
I didn't realize the drag links moved differently. You may have saved me the $400 for the redhead box I was eyeballing. I'll be looking at other options. Just found a tech article on the Toyota conversion and I'll be reading it this afternoon. Thanks for the quick reply.
There are two or three different ways of doing power steering on those trucks. Toyota conversion, original power steering which is about 900$ for the setup new. I think Harrison makes it as they made the originals, and another more sanitary conversion but I don't know who makes it. Similar to the Toyota conversion. Both the Toyota conversion and the other one I spoke of are cheaper than the original. There is also rack and pinion conversion. I have considered all three and even seen another conversion with a GM steering box, which I did not like as it hung down below the frame and was visible if standing off from the truck. As to steering improvements I would make sure the front spring bushings and shackle bushings are new or in very good condition, add a panhard bar and sway bar. Same with the rear.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
1991 Capri
2011 F250
2004 Lexus
I'm hoping to avoid power steering actually. I would prefer to stay manual. Mainly because I l don't want to try to attach a ps pump to the 223. The Toyota swap seems like a viable option if you don't mind building your own pitman arm. I'm not crazy about that personally. I am now looking at mustang ii or Dakota options as it seems to be the only actual manual rack option that I can afford as I can't find a crown Vic manual rack. I know no limit made a rack at some point by I guess it's long gone.
I'm surprised that No Limit stopped carrying them. It would be interesting to understand why. Performance Online makes a similar power rack and pinion; it might be worth checking if they would supply a manual one. CPP makes a replacement box and I believe they can supply the pitman arm. It is based on the now-rare Toyota. Someone posted recently about doing that conversion either here or on the FB forum.
I've solved this problem by picking up a crown Vic front end Saturday. Unfortunately I've brought on a few new ones. Like rear axle options to match lug patterns as well as attaching a power steering pump to a motor that never had one. It's a 223. And running a drive belt for said pump. Etc. more threads to come after I do some research. Thanks for the tips so far.
I think you made a good choice. Either CV or mustang II would be the way to really address steering.
- Roger Carter
Take a look at the electric power steering system used on newer vehicles. These conversions do away with the need for the hydraulics of a conventional power steering system.
I have see a how to video from a Mustang parts supplier on the conversion done to an early Mustang. I can't locate the link but I will keep searching and post it when I find it. The conversion would be very similar for a Slick.
Roger Carter
